GieltjE
Using DotNet 4.7.1 on X64 platform with WinSCP 5.12.1-beta during PutFiles to an OpenSSH 7.6 (SFTP) host it crashes quite often (see attached log).
This usually happens if there is a delay between files.
Description: stack trace
Re: Invalid access to memory.
GieltjE
Thanks, have been testing it but cannot seem to crash it again (with the mentioned build it used to be a 70% crash rate), could it be that this one contains some additional patches?
Not really.
So can you at least post a session log file from the official version (when it crashes)?
GieltjE
Finally got one, sending it via mail after compression (it's quite large).
-Edit- Sent it via wetransfer, your mailserver wouldn't accept the filesize.
GieltjE
Got another message: "Assertion failed: FPendingActions->Count == 0, file core\SessionInfo.cpp, line 1438", doesn't seem to be related to this bug though.
1) Were you able to reproduce the original problem with the new build?
2) Please send a log for the new problem too.
GieltjE
So far haven't been able to reproduce the problems with the new build (but I have been on vacation the past week so not much testing was done).
Will report in a few days
GieltjE
Managed to reproduce it, took some time reproduce it, hope the attached file helps.
  • WinSCP2618trace.7z (535.14 KB, Private file)
andylemmon
Utah
I also experienced the "invalid access to memory" WinSCP ver 576 on Windows 10.
It gave me some type of timeout error while I was deleting a directory on the left side user panel. Then this error:
(0070F590) TTerminal::GetIsCapable
(00088D2F) ntdll.dll
(0006FBF1) ntdll.dll.KiUserExceptionDispatcher
(003823D8) System::Actions::TContainedActionList::UpdateAction
(00169ECE) Vcl::Actnlist::TCustomAction::Update
(001DBD36) Vcl::Forms::_16777
(001DBDB4) Vcl::Forms::TCustomForm::UpdateActions
I had to shut WinSCP down via Task Manager as the error window was in loop I could not break out of.
Thanks. Will contact you in few days.
Can you reproduce the problem with the latest version of WinSCP? If you can please, post a separate report as this seems unrelated.
