Invalid Handle error
ChimChim
Greetings,
After I login to my SFTP server, I am encountering the following error when trying to access a Directory:
Invalid handle.
Error code: 9
Error message from server: The handle is invalid. (en)
Request code: 7
The applications I am using are:
client: WinSCP Version 3.7.6 (Build 306)
Server: VanDyke VShell Version 2.3.3 (build 217)
Session Log from WinSCP reports:
. 2005-11-14 10:42:46.900 Using SFTP protocol.
. 2005-11-14 10:42:46.900 Doing startup conversation with host.
> 2005-11-14 10:42:46.916 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2005-11-14 10:42:46.978 Type: SSH_FXP_VERSION, Size: 337, Number: -1
. 2005-11-14 10:42:46.978 SFTP version 4 negotiated.
. 2005-11-14 10:42:46.978 Unknown server extension newline@vandyke.com=0x000000020D0A
. 2005-11-14 10:42:46.978 Server requests EOL sequence 0x0D0A.
. 2005-11-14 10:42:46.978 File system roots:
. 2005-11-14 10:42:46.978 Unknown server extension default-fs-attribs@vandyke.com=...
. 2005-11-14 10:42:46.978 We will use UTF-8 strings when appropriate
. 2005-11-14 10:42:46.978 Getting current directory name.
. 2005-11-14 10:42:46.978 Getting real path for '.'
> 2005-11-14 10:42:46.978 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2005-11-14 10:42:47.041 Type: SSH_FXP_NAME, Size: 24, Number: 16
. 2005-11-14 10:42:47.041 Real path is 'sftp:/'
. 2005-11-14 10:42:47.041 Listing directory "sftp:/sftp:".
> 2005-11-14 10:42:47.041 Type: SSH_FXP_OPENDIR, Size: 20, Number: 267
< 2005-11-14 10:42:47.166 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2005-11-14 10:42:47.166 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2005-11-14 10:42:47.260 Type: SSH_FXP_NAME, Size: 159, Number: 524
> 2005-11-14 10:42:47.260 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2005-11-14 10:42:47.369 Type: SSH_FXP_STATUS, Size: 44, Number: 780
< 2005-11-14 10:42:47.369 Status/error code: 1
> 2005-11-14 10:42:47.369 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2005-11-14 10:42:47.369 Startup conversation with host finished.
. 2005-11-14 10:42:48.103 Detected incoming data while idle
. 2005-11-14 10:42:49.744 Changing directory to "HEALTHvision".
. 2005-11-14 10:42:49.744 Getting real path for 'sftp:/HEALTHvision'
> 2005-11-14 10:42:49.744 Type: SSH_FXP_REALPATH, Size: 27, Number: 1296
< 2005-11-14 10:42:49.744 Type: SSH_FXP_STATUS, Size: 34, Number: 1028
. 2005-11-14 10:42:49.744 Discarding reserved response
< 2005-11-14 10:42:49.838 Type: SSH_FXP_NAME, Size: 36, Number: 1296
. 2005-11-14 10:42:49.838 Real path is 'sftp:/HEALTHvision'
. 2005-11-14 10:42:49.838 Trying to open directory "sftp:/HEALTHvision".
> 2005-11-14 10:42:49.853 Type: SSH_FXP_LSTAT, Size: 37, Number: 1543
< 2005-11-14 10:42:49.916 Type: SSH_FXP_STATUS, Size: 42, Number: 1543
< 2005-11-14 10:42:49.916 Status/error code: 9, Message: 1543, Server: The handle is invalid. , Language: en
* 2005-11-14 10:42:49.916 (ECommand) Error changing directory to 'HEALTHvision'.
* 2005-11-14 10:42:49.916 Invalid handle.
* 2005-11-14 10:42:49.916 Error code: 9
* 2005-11-14 10:42:49.916 Error message from server: The handle is invalid. (en)
* 2005-11-14 10:42:49.916 Request code: 7
. 2005-11-14 10:47:12.150 Closing connection.
Any thoughts?
Please advise if more information is needed...
Reply with quote E-mail
ChimChim
Thanks for taking the time to look at this:
Debug Level 2:
. 2005-11-15 08:17:22.412 --------------------------------------------------------------------------
. 2005-11-15 08:17:22.412 WinSCP Version 3.7.6 (Build 306) (OS 5.1.2600 Service Pack 2)
. 2005-11-15 08:17:22.412 Login time: Tuesday, November 15, 2005 8:17:22 AM
. 2005-11-15 08:17:22.412 Session name: escott@sftp.healthvision.com
. 2005-11-15 08:17:22.412 Host name: sftp.healthvision.com (Port: 22)
. 2005-11-15 08:17:22.412 User name: escott (Password: No, Key file: Yes)
. 2005-11-15 08:17:22.412 Transfer Protocol: SFTP (SCP)
. 2005-11-15 08:17:22.412 SSH protocol version: 2; Compression: No
. 2005-11-15 08:17:22.412 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-11-15 08:17:22.412 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-11-15 08:17:22.412 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-11-15 08:17:22.412 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-11-15 08:17:22.412 SFTP Bugs: -,-,-
. 2005-11-15 08:17:22.412 Proxy: none
. 2005-11-15 08:17:22.412 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-11-15 08:17:22.412 Shell: default, EOL: 0
. 2005-11-15 08:17:22.412 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-11-15 08:17:22.412 Cache directory changes: Yes, Permanent: Yes
. 2005-11-15 08:17:22.412 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-11-15 08:17:22.412 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-11-15 08:17:22.412 Looking up host "sftp.healthvision.com"
. 2005-11-15 08:17:22.428 Connecting to 12.31.13.95 port 22
. 2005-11-15 08:17:22.522 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:22.522 Looking for incoming data
. 2005-11-15 08:17:22.663 Select result is 1
. 2005-11-15 08:17:22.663 Server version: SSH-2.0-VShell_2_3_3_217 VShell
. 2005-11-15 08:17:22.663 We claim version: SSH-2.0-WinSCP_release_3.7.6
. 2005-11-15 08:17:22.663 Using SSH protocol version 2
. 2005-11-15 08:17:22.663 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:22.663 Looking for incoming data
. 2005-11-15 08:17:22.804 Select result is 1
. 2005-11-15 08:17:22.804 Doing Diffie-Hellman group exchange
. 2005-11-15 08:17:22.804 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:22.804 Looking for incoming data
. 2005-11-15 08:17:23.211 Select result is 1
. 2005-11-15 08:17:23.211 Doing Diffie-Hellman key exchange
. 2005-11-15 08:17:23.414 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:23.414 Looking for incoming data
. 2005-11-15 08:17:23.962 Select result is 1
. 2005-11-15 08:17:24.212 Host key fingerprint is:
. 2005-11-15 08:17:24.212 ssh-dss 1024 f2:54:47:91:1c:e9:bc:04:7d:37:1b:9e:58:34:ac:82
. 2005-11-15 08:17:24.212 Initialised triple-DES client->server encryption
. 2005-11-15 08:17:24.212 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-11-15 08:17:24.212 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:24.212 Looking for incoming data
. 2005-11-15 08:17:24.212 Select result is 1
. 2005-11-15 08:17:24.212 Initialised triple-DES server->client encryption
. 2005-11-15 08:17:24.212 Initialised HMAC-SHA1 server->client MAC algorithm
. 2005-11-15 08:17:24.494 Select result is 1
! 2005-11-15 08:17:24.494 Using username "escott".
. 2005-11-15 08:17:24.494 Reading private key file "C:\Documents and Settings\kbeaudre\Application Data\SSH\UserKeys\winscp01.ppk"
. 2005-11-15 08:17:24.494 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:24.494 Looking for incoming data
. 2005-11-15 08:17:24.541 Select result is 1
. 2005-11-15 08:17:24.541 Offered public key
. 2005-11-15 08:17:24.541 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:24.541 Looking for incoming data
. 2005-11-15 08:17:24.870 Select result is 1
. 2005-11-15 08:17:24.870 Offer of public key accepted
! 2005-11-15 08:17:24.870 Authenticating with public key "dsa-key-20041213"
. 2005-11-15 08:17:24.870 Passphrase prompt (Passphrase for key "dsa-key-20041213": )
. 2005-11-15 08:17:28.188 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:28.188 Looking for incoming data
. 2005-11-15 08:17:28.485 Select result is 1
. 2005-11-15 08:17:28.485 Access granted
. 2005-11-15 08:17:28.485 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:28.485 Looking for incoming data
. 2005-11-15 08:17:28.532 Select result is 1
. 2005-11-15 08:17:28.532 Opened channel for session
. 2005-11-15 08:17:28.532 Waiting for the server to continue with the initialisation
. 2005-11-15 08:17:28.532 Looking for incoming data
. 2005-11-15 08:17:28.595 Select result is 1
. 2005-11-15 08:17:28.595 Started a shell/command
. 2005-11-15 08:17:28.595 --------------------------------------------------------------------------
. 2005-11-15 08:17:28.595 Using SFTP protocol.
. 2005-11-15 08:17:28.595 Doing startup conversation with host.
> 2005-11-15 08:17:28.595 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2005-11-15 08:17:28.595 01,00,00,00,05,
. 2005-11-15 08:17:28.595 Sent 9 bytes
. 2005-11-15 08:17:28.595 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:28.595 Waiting for another 4 bytes
. 2005-11-15 08:17:28.595 Looking for incoming data
. 2005-11-15 08:17:28.657 Select result is 1
. 2005-11-15 08:17:28.657 Received 4 bytes
. 2005-11-15 08:17:28.657 Received 337 bytes
< 2005-11-15 08:17:28.657 Type: SSH_FXP_VERSION, Size: 337, Number: -1
< 2005-11-15 08:17:28.657 02,00,00,00,04,00,00,00,13,6E,65,77,6C,69,6E,65,40,76,61,6E,64,79,6B,65,2E,
< 2005-11-15 08:17:28.657 63,6F,6D,00,00,00,06,00,00,00,02,0D,0A,00,00,00,07,6E,65,77,6C,69,6E,65,00,
< 2005-11-15 08:17:28.657 00,00,02,0D,0A,00,00,00,14,66,73,2D,72,6F,6F,74,73,40,76,61,6E,64,79,6B,65,
< 2005-11-15 08:17:28.657 2E,63,6F,6D,00,00,00,0D,00,00,00,04,73,66,74,70,07,00,00,00,00,00,00,00,1E,
< 2005-11-15 08:17:28.657 64,65,66,61,75,6C,74,2D,66,73,2D,61,74,74,72,69,62,73,40,76,61,6E,64,79,6B,
< 2005-11-15 08:17:28.657 65,2E,63,6F,6D,00,00,00,CB,00,00,00,01,00,00,00,09,5C,2F,3A,2A,3F,22,3C,3E,
< 2005-11-15 08:17:28.657 7C,00,00,00,17,00,00,00,04,43,4F,4D,31,00,00,00,04,43,4F,4D,32,00,00,00,04,
< 2005-11-15 08:17:28.657 43,4F,4D,33,00,00,00,04,43,4F,4D,34,00,00,00,04,43,4F,4D,35,00,00,00,04,43,
< 2005-11-15 08:17:28.657 4F,4D,36,00,00,00,04,43,4F,4D,37,00,00,00,04,43,4F,4D,38,00,00,00,04,43,4F,
< 2005-11-15 08:17:28.657 4D,39,00,00,00,04,4C,50,54,31,00,00,00,04,4C,50,54,32,00,00,00,04,4C,50,54,
< 2005-11-15 08:17:28.657 33,00,00,00,04,4C,50,54,34,00,00,00,04,4C,50,54,35,00,00,00,04,4C,50,54,36,
< 2005-11-15 08:17:28.657 00,00,00,04,4C,50,54,37,00,00,00,04,4C,50,54,38,00,00,00,04,4C,50,54,39,00,
< 2005-11-15 08:17:28.657 00,00,03,50,52,4E,00,00,00,03,43,4F,4E,00,00,00,03,41,55,58,00,00,00,03,4E,
< 2005-11-15 08:17:28.657 55,4C,00,00,00,06,43,4C,4F,43,4B,24,
. 2005-11-15 08:17:28.657 SFTP version 4 negotiated.
. 2005-11-15 08:17:28.657 Unknown server extension newline@vandyke.com=0x000000020D0A
. 2005-11-15 08:17:28.657 Server requests EOL sequence 0x0D0A.
. 2005-11-15 08:17:28.657 File system roots:
. 2005-11-15 08:17:28.657 Unknown server extension default-fs-attribs@vandyke.com=...
. 2005-11-15 08:17:28.657 We will use UTF-8 strings when appropriate
. 2005-11-15 08:17:28.657 Getting current directory name.
. 2005-11-15 08:17:28.657 Getting real path for '.'
> 2005-11-15 08:17:28.657 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2005-11-15 08:17:28.657 10,00,00,00,10,00,00,00,01,2E,
. 2005-11-15 08:17:28.657 Sent 14 bytes
. 2005-11-15 08:17:28.657 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:28.657 Waiting for another 4 bytes
. 2005-11-15 08:17:28.657 Looking for incoming data
. 2005-11-15 08:17:28.720 Select result is 1
. 2005-11-15 08:17:28.720 Received 4 bytes
. 2005-11-15 08:17:28.720 Received 24 bytes
< 2005-11-15 08:17:28.720 Type: SSH_FXP_NAME, Size: 24, Number: 16
< 2005-11-15 08:17:28.720 68,00,00,00,10,00,00,00,01,00,00,00,06,73,66,74,70,3A,2F,00,00,00,00,02,
. 2005-11-15 08:17:28.720 Real path is 'sftp:/'
. 2005-11-15 08:17:28.720 Listing directory "sftp:/sftp:".
> 2005-11-15 08:17:28.720 Type: SSH_FXP_OPENDIR, Size: 20, Number: 267
> 2005-11-15 08:17:28.720 0B,00,00,01,0B,00,00,00,0B,73,66,74,70,3A,2F,73,66,74,70,3A,
. 2005-11-15 08:17:28.720 Sent 24 bytes
. 2005-11-15 08:17:28.720 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:28.720 Waiting for another 4 bytes
. 2005-11-15 08:17:28.720 Looking for incoming data
. 2005-11-15 08:17:28.767 Select result is 1
. 2005-11-15 08:17:28.767 Received 4 bytes
. 2005-11-15 08:17:28.767 Received 13 bytes
< 2005-11-15 08:17:28.767 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2005-11-15 08:17:28.767 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2005-11-15 08:17:28.767 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2005-11-15 08:17:28.767 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2005-11-15 08:17:28.767 Sent 17 bytes
. 2005-11-15 08:17:28.767 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:28.767 Waiting for another 4 bytes
. 2005-11-15 08:17:28.767 Looking for incoming data
. 2005-11-15 08:17:28.830 Select result is 1
. 2005-11-15 08:17:28.830 Received 4 bytes
. 2005-11-15 08:17:28.830 Received 159 bytes
< 2005-11-15 08:17:28.830 Type: SSH_FXP_NAME, Size: 159, Number: 524
< 2005-11-15 08:17:28.830 68,00,00,02,0C,00,00,00,03,00,00,00,01,2E,00,00,02,39,02,00,00,00,00,00,00,
< 2005-11-15 08:17:28.830 00,00,00,00,00,00,43,79,E2,E0,00,00,00,00,40,A9,63,FC,00,00,00,00,42,DF,CA,
< 2005-11-15 08:17:28.830 51,00,00,00,10,00,00,00,02,2E,2E,00,00,02,39,02,00,00,00,00,00,00,00,00,00,
< 2005-11-15 08:17:28.830 00,00,00,43,79,E2,E0,00,00,00,00,40,A9,63,FC,00,00,00,00,42,DF,CA,51,00,00,
< 2005-11-15 08:17:28.830 00,10,00,00,00,0C,48,45,41,4C,54,48,76,69,73,69,6F,6E,00,00,02,39,02,00,00,
< 2005-11-15 08:17:28.830 00,00,00,00,00,00,00,00,00,00,43,79,E2,E0,00,00,00,00,40,A9,64,D3,00,00,00,
< 2005-11-15 08:17:28.830 00,43,59,47,97,00,00,00,10,
> 2005-11-15 08:17:28.830 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2005-11-15 08:17:28.830 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2005-11-15 08:17:28.830 Sent 17 bytes
. 2005-11-15 08:17:28.830 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:28.830 Waiting for another 4 bytes
. 2005-11-15 08:17:28.830 Looking for incoming data
. 2005-11-15 08:17:28.892 Select result is 1
. 2005-11-15 08:17:28.892 Received 4 bytes
. 2005-11-15 08:17:28.892 Received 44 bytes
< 2005-11-15 08:17:28.892 Type: SSH_FXP_STATUS, Size: 44, Number: 780
< 2005-11-15 08:17:28.892 65,00,00,03,0C,00,00,00,01,00,00,00,19,54,68,65,72,65,20,61,72,65,20,6E,6F,
< 2005-11-15 08:17:28.892 20,6D,6F,72,65,20,66,69,6C,65,73,2E,20,00,00,00,02,65,6E,
< 2005-11-15 08:17:28.892 Status/error code: 1
> 2005-11-15 08:17:28.892 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
> 2005-11-15 08:17:28.892 04,00,00,04,04,00,00,00,04,00,00,00,00,
. 2005-11-15 08:17:28.892 Sent 17 bytes
. 2005-11-15 08:17:28.892 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:28.892 Startup conversation with host finished.
. 2005-11-15 08:17:29.628 Session upkeep
. 2005-11-15 08:17:29.628 Select result is 1
. 2005-11-15 08:17:29.628 Detected incoming data while idle
. 2005-11-15 08:17:30.129 Session upkeep
. 2005-11-15 08:17:30.129 Select result is 0
. 2005-11-15 08:17:30.630 Session upkeep
. 2005-11-15 08:17:30.630 Select result is 0
. 2005-11-15 08:17:30.958 Changing directory to "HEALTHvision".
. 2005-11-15 08:17:30.958 Getting real path for 'sftp:/HEALTHvision'
> 2005-11-15 08:17:30.958 Type: SSH_FXP_REALPATH, Size: 27, Number: 1296
> 2005-11-15 08:17:30.958 10,00,00,05,10,00,00,00,12,73,66,74,70,3A,2F,48,45,41,4C,54,48,76,69,73,69,
> 2005-11-15 08:17:30.958 6F,6E,
. 2005-11-15 08:17:30.958 Sent 31 bytes
. 2005-11-15 08:17:30.958 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:30.958 Received 4 bytes
. 2005-11-15 08:17:30.958 Received 34 bytes
< 2005-11-15 08:17:30.958 Type: SSH_FXP_STATUS, Size: 34, Number: 1028
< 2005-11-15 08:17:30.958 65,00,00,04,04,00,00,00,00,00,00,00,0F,53,46,54,50,5F,49,5F,53,55,43,43,45,
< 2005-11-15 08:17:30.958 53,53,20,00,00,00,02,65,6E,
. 2005-11-15 08:17:30.958 Discarding reserved response
. 2005-11-15 08:17:30.958 Waiting for another 4 bytes
. 2005-11-15 08:17:30.958 Looking for incoming data
. 2005-11-15 08:17:31.021 Select result is 1
. 2005-11-15 08:17:31.021 Received 4 bytes
. 2005-11-15 08:17:31.021 Received 36 bytes
< 2005-11-15 08:17:31.021 Type: SSH_FXP_NAME, Size: 36, Number: 1296
< 2005-11-15 08:17:31.021 68,00,00,05,10,00,00,00,01,00,00,00,12,73,66,74,70,3A,2F,48,45,41,4C,54,48,
< 2005-11-15 08:17:31.021 76,69,73,69,6F,6E,00,00,00,00,02,
. 2005-11-15 08:17:31.021 Real path is 'sftp:/HEALTHvision'
. 2005-11-15 08:17:31.021 Trying to open directory "sftp:/HEALTHvision".
> 2005-11-15 08:17:31.021 Type: SSH_FXP_LSTAT, Size: 37, Number: 1543
> 2005-11-15 08:17:31.021 07,00,00,06,07,00,00,00,18,73,66,74,70,3A,2F,73,66,74,70,3A,2F,48,45,41,4C,
> 2005-11-15 08:17:31.021 54,48,76,69,73,69,6F,6E,00,00,00,AD,
. 2005-11-15 08:17:31.021 Sent 41 bytes
. 2005-11-15 08:17:31.021 There are 0 bytes remaining in the send buffer
. 2005-11-15 08:17:31.021 Waiting for another 4 bytes
. 2005-11-15 08:17:31.021 Looking for incoming data
. 2005-11-15 08:17:31.083 Select result is 1
. 2005-11-15 08:17:31.083 Received 4 bytes
. 2005-11-15 08:17:31.083 Received 42 bytes
< 2005-11-15 08:17:31.083 Type: SSH_FXP_STATUS, Size: 42, Number: 1543
< 2005-11-15 08:17:31.083 65,00,00,06,07,00,00,00,09,00,00,00,17,54,68,65,20,68,61,6E,64,6C,65,20,69,
< 2005-11-15 08:17:31.083 73,20,69,6E,76,61,6C,69,64,2E,20,00,00,00,02,65,6E,
< 2005-11-15 08:17:31.083 Status/error code: 9, Message: 1543, Server: The handle is invalid. , Language: en
* 2005-11-15 08:17:31.083 (ECommand) Error changing directory to 'HEALTHvision'.
* 2005-11-15 08:17:31.083 Invalid handle.
* 2005-11-15 08:17:31.083 Error code: 9
* 2005-11-15 08:17:31.083 Error message from server: The handle is invalid. (en)
* 2005-11-15 08:17:31.083 Request code: 7
. 2005-11-15 08:17:31.130 Session upkeep
. 2005-11-15 08:17:31.146 Select result is 0
. 2005-11-15 08:17:31.631 Session upkeep
. 2005-11-15 08:17:31.631 Select result is 0
. 2005-11-15 08:17:32.132 Session upkeep
. 2005-11-15 08:17:32.132 Select result is 0
. 2005-11-15 08:17:32.633 Session upkeep
. 2005-11-15 08:17:32.633 Select result is 0
. 2005-11-15 08:17:33.134 Session upkeep
. 2005-11-15 08:17:33.134 Select result is 0
. 2005-11-15 08:17:33.635 Session upkeep
. 2005-11-15 08:17:33.635 Select result is 0
. 2005-11-15 08:17:34.136 Session upkeep
. 2005-11-15 08:17:34.136 Select result is 0
. 2005-11-15 08:17:34.636 Session upkeep
. 2005-11-15 08:17:34.636 Select result is 0
. 2005-11-15 08:17:35.137 Session upkeep
. 2005-11-15 08:17:35.137 Select result is 0
. 2005-11-15 08:17:35.638 Session upkeep
. 2005-11-15 08:17:35.638 Select result is 0
. 2005-11-15 08:17:36.139 Session upkeep
. 2005-11-15 08:17:36.139 Select result is 0
. 2005-11-15 08:17:36.640 Session upkeep
. 2005-11-15 08:17:36.640 Select result is 0
. 2005-11-15 08:17:37.141 Session upkeep
. 2005-11-15 08:17:37.141 Select result is 0
. 2005-11-15 08:17:37.313 Session upkeep
. 2005-11-15 08:17:37.313 Select result is 0
. 2005-11-15 08:17:37.407 Closing connection.
The error message doesn't make much sense for the request being issued to the server. Have you tried upgrading the server? Your version is quote old.
ChimChim
Perhaps the version is a bit out of date, and upgrading it is certainly an option. The point is the process did work - now it doesn't. I can't rule out the possibility of a Microsoft patch causing an issue, but statements in the debug log like "2005-11-15 08:17:28.657 Unknown server extension " disturb me. I would just like to understand what changed.
That's OK. Vandyke SFTP server has number of proprietary extensions that WinSCP does not understand. BTW, I use the Vandyke server for Windows as primary SFTP server for testing WinSCP, so I know that it is working fine with it.
ChimChim
Forgive me if I am being dense, but if I can get sessions to work properly through PuTTY and SSH.COM's clients, but NOT through WinSCP, then I am led to beleive that the problem is WinSCP. I just don't know what that problem could be - especially since I had everything working great with WinSCP.
The problem is with SFTP, so it has nothing to do with PuTTY (if you do not mean PSFTP). SSH.COM clients may work for numerous reasons. First, it may not use the SSH_FXP_LSTAT command, which is the one that fail. Also they may use different version of the SFTP protocol and the bug on the server (if there is some) may show only with the version WinSCP uses.
kshv
I am having same problem between winscp and VShell 2.3.3
I have one more observation made. I don't see this problem if I use older versions of winscp older than 3.6.7 which makes me believe that something changed in the later versions of winscp that is causing this issue. Thought this might help.
Try to upgrade your VShell server. I have the problems with 2.3x too. 2.5 works fine (and some later 2.3x too).
kshv
Further, I observed that when a windows 2000 server was updated with "rollup1 update for windows 2000 sp4" overwrite operation on files fails with an error message "handle is invalid".
This is observed with Winscp alone. Other SSH clients like Tunnelier, SecureFX, CoreFTP doesn't have this problem.
It looks to me like it is a combinational problem between winscp and Windows 2000 sp4 with rollup1 update.
Updating the VShell server to latest version didn't make any difference.
Thanks for providing WinSCP tool.
kshv
kshv
Winscp debug-2 Log
. 2006-04-04 17:06:38.089 --------------------------------------------------------------------------
. 2006-04-04 17:06:38.089 WinSCP Version 3.8.0 (Build 312) (OS 5.1.2600 Service Pack 2)
. 2006-04-04 17:06:38.089 Login time: Tuesday, April 04, 2006 5:06:38 PM
. 2006-04-04 17:06:38.089 Session name: xxxxxxUser@xxxxxx
. 2006-04-04 17:06:38.089 Host name: xxxxxx (Port: 22)
. 2006-04-04 17:06:38.089 User name: xxxxxxUser (Password: Yes, Key file: No)
. 2006-04-04 17:06:38.089 Transfer Protocol: SFTP (SCP)
. 2006-04-04 17:06:38.089 SSH protocol version: 2; Compression: No
. 2006-04-04 17:06:38.089 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-04-04 17:06:38.089 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-04-04 17:06:38.089 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-04-04 17:06:38.089 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-04-04 17:06:38.089 SFTP Bugs: -,-,-
. 2006-04-04 17:06:38.089 Proxy: none
. 2006-04-04 17:06:38.089 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-04-04 17:06:38.089 Shell: default, EOL: 0
. 2006-04-04 17:06:38.089 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-04-04 17:06:38.089 Cache directory changes: Yes, Permanent: Yes
. 2006-04-04 17:06:38.089 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-04-04 17:06:38.089 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-04-04 17:06:38.089 Looking up host "xxxxxx"
. 2006-04-04 17:06:38.089 Connecting to X.X.X.X port 22
. 2006-04-04 17:06:38.089 Waiting for the server to continue with the initialisation
. 2006-04-04 17:06:38.089 Looking for incoming data
. 2006-04-04 17:06:38.089 Select result is 1
. 2006-04-04 17:06:38.089 Server version: SSH-2.0-VShell_2_3_3_217 VShell
. 2006-04-04 17:06:38.089 We claim version: SSH-2.0-WinSCP_release_3.8
. 2006-04-04 17:06:38.089 Using SSH protocol version 2
. 2006-04-04 17:06:38.099 Select result is 1
. 2006-04-04 17:06:38.099 Doing Diffie-Hellman group exchange
. 2006-04-04 17:06:38.099 Waiting for the server to continue with the initialisation
. 2006-04-04 17:06:38.099 Looking for incoming data
. 2006-04-04 17:06:38.239 Select result is 1
. 2006-04-04 17:06:38.239 Doing Diffie-Hellman key exchange
. 2006-04-04 17:06:38.390 Waiting for the server to continue with the initialisation
. 2006-04-04 17:06:38.390 Looking for incoming data
. 2006-04-04 17:06:38.450 Select result is 1
. 2006-04-04 17:06:38.640 Host key fingerprint is:
. 2006-04-04 17:06:38.640 ssh-dss 1024 a9:56:bb:64:36:10:51:0e:b0:05:61:0f:4d:76
. 2006-04-04 17:06:38.640 Initialised AES-256 client->server encryption
. 2006-04-04 17:06:38.640 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-04-04 17:06:38.640 Waiting for the server to continue with the initialisation
. 2006-04-04 17:06:38.640 Looking for incoming data
. 2006-04-04 17:06:38.640 Select result is 1
. 2006-04-04 17:06:38.640 Initialised AES-256 server->client encryption
. 2006-04-04 17:06:38.640 Initialised HMAC-SHA1 server->client MAC algorithm
. 2006-04-04 17:06:38.840 Select result is 1
! 2006-04-04 17:06:38.840 Using username "xxxxxxUser".
. 2006-04-04 17:06:38.840 Waiting for the server to continue with the initialisation
. 2006-04-04 17:06:38.840 Looking for incoming data
! 2006-04-04 17:06:38.840 WARNING!!!
. 2006-04-04 17:06:39.822 Waiting for the server to continue with the initialisation
. 2006-04-04 17:06:39.822 Looking for incoming data
. 2006-04-04 17:06:39.822 Select result is 1
. 2006-04-04 17:06:39.822 Session password prompt (xxxxxxUser@xxxxxx's password: )
. 2006-04-04 17:06:39.822 Using stored password.
. 2006-04-04 17:06:39.822 Sent password
. 2006-04-04 17:06:39.822 Access granted
. 2006-04-04 17:06:39.822 Opened channel for session
. 2006-04-04 17:06:39.822 Started a shell/command
. 2006-04-04 17:06:39.822 --------------------------------------------------------------------------
. 2006-04-04 17:06:39.822 Using SFTP protocol.
. 2006-04-04 17:06:39.822 Doing startup conversation with host.
> 2006-04-04 17:06:39.822 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2006-04-04 17:06:39.832 01,00,00,00,05,
. 2006-04-04 17:06:39.832 Sent 9 bytes
. 2006-04-04 17:06:39.832 There are 0 bytes remaining in the send buffer
. 2006-04-04 17:06:39.832 Waiting for another 4 bytes
. 2006-04-04 17:06:39.832 Looking for incoming data
. 2006-04-04 17:06:39.832 Select result is 1
. 2006-04-04 17:06:39.832 Received 4 bytes
. 2006-04-04 17:06:39.832 Received 364 bytes
< 2006-04-04 17:06:39.832 Type: SSH_FXP_VERSION, Size: 364, Number: -1
< 2006-04-04 17:06:39.832 02,00,00,00,04,00,00,00,13,6E,65,77,6C,69,6E,65,40,76,61,6E,64,79,6B,65,2E,
< 2006-04-04 17:06:39.832 63,6F,6D,00,00,00,06,00,00,00,02,0D,0A,00,00,00,07,6E,65,77,6C,69,6E,65,00,
< 2006-04-04 17:06:39.832 00,00,02,0D,0A,00,00,00,14,66,73,2D,72,6F,6F,74,73,40,76,61,6E,64,79,6B,65,
< 2006-04-04 17:06:39.832 2E,63,6F,6D,00,00,00,28,00,00,00,01,41,02,00,00,00,01,43,03,00,00,00,01,44,
< 2006-04-04 17:06:39.832 03,00,00,00,01,45,03,00,00,00,01,46,04,00,00,00,01,5A,05,00,00,00,00,00,00,
< 2006-04-04 17:06:39.832 SFTP version 4 negotiated.
. 2006-04-04 17:06:39.832 Unknown server extension newline@vandyke.com=0x000000020D0A
. 2006-04-04 17:06:39.832 Server requests EOL sequence 0x0D0A.
. 2006-04-04 17:06:39.832 File system roots:
. 2006-04-04 17:06:39.832 A: (type 2)
. 2006-04-04 17:06:39.832 C: (type 3)
. 2006-04-04 17:06:39.832 D: (type 3)
. 2006-04-04 17:06:39.832 E: (type 3)
. 2006-04-04 17:06:39.832 F: (type 4)
. 2006-04-04 17:06:39.832 Z: (type 5)
. 2006-04-04 17:06:39.832 Unknown server extension default-fs-attribs@vandyke.com=
0x00000001000000095C2F3A2A3F223C3E7C0000001700000004434F4D3100000004434F4D32000000
04434F4D3300000004434F4D3400000004434F4D3500000004434F4D3600000004434F4D3700000004
434F4D3800000004434F4D39000000044C505431000000044C505432000000044C505433000000044C
505434000000044C505435000000044C505436000000044C505437000000044C505438000000044C50
54390000000350524E00000003434F4E00000003415558000000034E554C00000006434C4F434B24
. 2006-04-04 17:06:39.832 We will use UTF-8 strings when appropriate
. 2006-04-04 17:06:39.832 Getting current directory name.
. 2006-04-04 17:06:39.832 Getting real path for '.'
> 2006-04-04 17:06:39.832 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2006-04-04 17:06:39.832 10,00,00,00,10,00,00,00,01,2E,
. 2006-04-04 17:06:39.832 Sent 14 bytes
. 2006-04-04 17:06:39.832 Received 21 bytes
< 2006-04-04 17:06:39.832 Type: SSH_FXP_NAME, Size: 21, Number: 16
< 2006-04-04 17:06:39.832 68,00,00,00,10,00,00,00,01,00,00,00,03,43,3A,2F,00,00,00,00,02,
. 2006-04-04 17:06:39.832 Real path is 'C:/'
. 2006-04-04 17:06:39.832 Listing directory "C:".
> 2006-04-04 17:06:39.832 Type: SSH_FXP_OPENDIR, Size: 11, Number: 267
> 2006-04-04 17:06:39.832 0B,00,00,01,0B,00,00,00,02,43,3A,
. 2006-04-04 17:06:39.832 Sent 15 bytes
. 2006-04-04 17:06:39.832 Received 13 bytes
< 2006-04-04 17:06:39.832 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2006-04-04 17:06:39.832 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2006-04-04 17:06:39.832 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2006-04-04 17:06:39.832 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:06:39.832 Sent 17 bytes
. 2006-04-04 17:06:39.832 Received 1363 bytes
< 2006-04-04 17:06:39.832 Type: SSH_FXP_NAME, Size: 1363, Number: 524
< 2006-04-04 17:06:39.832 68,00,00,02,0C,00,00,00,19,00,00,00,0B,24,4D,46,43,4C,69,63,65,6E,73,65,00,
< 2006-04-04 17:06:39.832 00,02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4A,B4,00,00,00,00,40,
< 2006-04-04 17:06:39.832 EC,05,6C,00,00,00,00,41,11,4F,55,00,00,00,10,00,00,00,04,2E,72,6E,64,00,00,
< 2006-04-04 17:06:39.832 02,39,01,00,00,00,00,00,00,04,00,00,00,00,00,42,AD,DF,A2,00,00,00,00,42,4C,
< 2006-04-04 17:06:39.832 49,50,00,00,00,00,42,4D,5F,0B,00,00,00,10,00,00,00,0F,41,62,61,74,49,6E,73,
< 2006-04-04 17:06:39.832 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2006-04-04 17:06:39.832 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:06:39.842 Received 4 bytes
. 2006-04-04 17:06:39.842 Received 1356 bytes
< 2006-04-04 17:06:39.842 Type: SSH_FXP_NAME, Size: 1356, Number: 780
< 2006-04-04 17:06:39.842 68,00,00,03,0C,00,00,00,19,00,00,00,07,6C,6F,67,2E,74,78,74,00,00,02,39,01,
< 2006-04-04 17:06:39.842 00,00,00,00,00,04,EB,FA,00,00,00,00,43,51,CC,4B,00,00,00,00,43,51,CC,45,00,
< 2006-04-04 17:06:39.842 00,00,00,43,51,CC,4B,00,00,00,10,00,00,00,04,4C,4F,47,53,00,00,02,39,02,00,
< 2006-04-04 17:06:39.842 00,00,00,00,00,00,00,00,00,00,00,44,2F,76,A6,00,00,00,00,40,E5,DE,F7,00,00,
< 2006-04-04 17:06:39.842 00,00,40,E5,DE,F7,00,00,00,10,00,00,00,09,4D,53,44,4F,53,2E,53,59,53,00,00,
< 2006-04-04 17:06:39.842 02,39,01,00,00,00,00,00,00,00,00,00,00,00,00,40,E5,73,F4,00,00,00,00,40,E5,
> 2006-04-04 17:06:39.842 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
> 2006-04-04 17:06:39.842 0C,00,00,04,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:06:39.842 Sent 17 bytes
. 2006-04-04 17:06:39.842 There are 0 bytes remaining in the send buffer
. 2006-04-04 17:06:39.842 Waiting for another 4 bytes
. 2006-04-04 17:06:39.842 Looking for incoming data
. 2006-04-04 17:06:39.842 Select result is 1
. 2006-04-04 17:06:39.842 Received 564 bytes
< 2006-04-04 17:06:39.842 Type: SSH_FXP_NAME, Size: 564, Number: 1036
< 2006-04-04 17:06:39.842 68,00,00,04,0C,00,00,00,0A,00,00,00,0A,74,73,6D,5F,69,6D,61,67,65,73,00,00,
< 2006-04-04 17:06:39.842 02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,2C,00,00,00,00,42,72,
< 2006-04-04 17:06:39.842 9B,BE,00,00,00,00,42,72,9B,BE,00,00,00,10,00,00,00,0C,55,6E,69,6E,73,74,52,
< 2006-04-04 17:06:39.842 41,2E,6C,6F,67,00,00,02,39,01,00,00,00,00,00,00,03,72,00,00,00,00,42,AD,DF,
< 2006-04-04 17:06:39.842 A2,00,00,00,00,41,EA,7B,32,00,00,00,00,41,EA,7B,32,00,00,00,10,00,00,00,05,
< 2006-04-04 17:06:39.842 75,74,69,6C,73,00,00,02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,
< 2006-04-04 17:06:39.842 2D,00,00,00,00,40,E5,2B,A3,00,00,00,00,40,E5,DE,F7,00,00,00,10,00,00,00,05,
< 2006-04-04 17:06:39.842 55,58,4C,6F,67,00,00,02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,
< 2006-04-04 17:06:39.842 2D,00,00,00,00,40,E5,D2,ED,00,00,00,00,40,E5,D2,FD,00,00,00,10,00,00,00,0A,
< 2006-04-04 17:06:39.842 56,53,68,65,6C,6C,42,6B,75,70,00,00,02,39,02,00,00,00,00,00,00,00,00,00,00,
< 2006-04-04 17:06:39.842 00,00,44,32,4B,2D,00,00,00,00,42,3D,88,A2,00,00,00,00,44,22,B9,AB,00,00,00,
< 2006-04-04 17:06:39.842 10,00,00,00,19,56,53,68,65,6C,6C,43,6F,6E,6E,65,63,74,69,6F,6E,4C,69,6D,69,
< 2006-04-04 17:06:39.842 74,2E,72,74,66,00,00,02,39,01,00,00,00,00,00,18,B0,A0,00,00,00,00,43,9F,56,
< 2006-04-04 17:06:39.842 88,00,00,00,00,43,9F,32,D1,00,00,00,00,43,9F,32,D1,00,00,00,10,00,00,00,14,
< 2006-04-04 17:06:39.842 56,53,68,65,6C,6C,53,72,76,53,74,6F,70,70,65,64,2E,72,74,66,00,00,02,39,01,
< 2006-04-04 17:06:39.842 00,00,00,00,00,18,B0,A0,00,00,00,00,44,20,69,2F,00,00,00,00,43,9F,33,49,00,
< 2006-04-04 17:06:39.842 00,00,00,43,9F,33,49,00,00,00,10,00,00,00,07,77,65,73,2E,74,78,74,00,00,02,
< 2006-04-04 17:06:39.842 39,01,00,00,00,00,00,00,00,03,00,00,00,00,44,32,E9,73,00,00,00,00,42,5E,D3,
< 2006-04-04 17:06:39.842 B0,00,00,00,00,42,5E,D3,B8,00,00,00,10,00,00,00,05,57,49,4E,4E,54,00,00,02,
< 2006-04-04 17:06:39.842 39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,E4,5E,00,00,00,00,40,E5,2A,
< 2006-04-04 17:06:39.842 C6,00,00,00,00,44,1D,7F,57,00,00,00,10,00,00,00,06,57,69,6E,53,43,50,00,00,
< 2006-04-04 17:06:39.842 02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,2D,00,00,00,00,40,FE,
< 2006-04-04 17:06:39.842 C7,52,00,00,00,00,40,FE,C7,56,00,00,00,10,
> 2006-04-04 17:06:39.842 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
> 2006-04-04 17:06:39.842 0C,00,00,05,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:06:39.842 Received 44 bytes
< 2006-04-04 17:06:39.842 Type: SSH_FXP_STATUS, Size: 44, Number: 1292
< 2006-04-04 17:06:39.842 65,00,00,05,0C,00,00,00,01,00,00,00,19,54,68,65,72,65,20,61,72,65,20,6E,6F,
< 2006-04-04 17:06:39.842 20,6D,6F,72,65,20,66,69,6C,65,73,2E,20,00,00,00,02,65,6E,
< 2006-04-04 17:06:39.842 Status/error code: 1
> 2006-04-04 17:06:39.842 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
> 2006-04-04 17:06:39.842 04,00,00,06,04,00,00,00,04,00,00,00,00,
. 2006-04-04 17:06:39.842 Startup conversation with host finished.
. 2006-04-04 17:06:40.563 Session upkeep
. 2006-04-04 17:06:40.563 Select result is 1
. 2006-04-04 17:06:40.563 Detected incoming data while idle
. 2006-04-04 17:06:41.064 Session upkeep
. 2006-04-04 17:06:41.064 Select result is 0
. 2006-04-04 17:06:41.564 Session upkeep
. 2006-04-04 17:06:41.564 Select result is 0
. 2006-04-04 17:06:42.065 Session upkeep
. 2006-04-04 17:06:42.065 Select result is 0
. 2006-04-04 17:06:42.566 Session upkeep
. 2006-04-04 17:07:13.110 Session upkeep
. 2006-04-04 17:07:13.110 Select result is 0
. 2006-04-04 17:07:13.610 Session upkeep
. 2006-04-04 17:07:13.610 Select result is 0
. 2006-04-04 17:07:14.111 Session upkeep
. 2006-04-04 17:07:14.111 Select result is 0
. 2006-04-04 17:07:14.171 Copying 1 files/directories to remote directory "C:/"
. 2006-04-04 17:07:14.171 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-04-04 17:07:14.171 TM: M; ClAr: No; ExclM(No):
. 2006-04-04 17:07:14.171 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-04-04 17:07:14.171 File: "C:\Documents and Settings\xxxxxx\Desktop\TestWin.txt"
. 2006-04-04 17:07:14.171 Copying "C:\Documents and Settings\xxxxxx\Desktop\TestWin.txt" to remote directory started.
. 2006-04-04 17:07:14.171 Ascii transfer mode selected.
. 2006-04-04 17:07:14.171 Opening remote file.
> 2006-04-04 17:07:14.171 Type: SSH_FXP_OPEN, Size: 43, Number: 1795
> 2006-04-04 17:07:14.171 03,00,00,07,03,00,00,00,11,43,3A,2F,43,3A,2F,54,65,73,74,57,69,6E,2E,74,78,
> 2006-04-04 17:07:14.171 74,00,00,00,7A,00,00,00,01,01,00,00,00,00,00,00,00,0B,
. 2006-04-04 17:07:14.171 Sent 47 bytes
. 2006-04-04 17:07:14.171 There are 0 bytes remaining in the send buffer
. 2006-04-04 17:07:14.171 Received 4 bytes
. 2006-04-04 17:07:14.171 Received 34 bytes
< 2006-04-04 17:07:14.171 Type: SSH_FXP_STATUS, Size: 34, Number: 1540
< 2006-04-04 17:07:14.171 65,00,00,06,04,00,00,00,00,00,00,00,0F,53,46,54,50,5F,49,5F,53,55,43,43,45,
< 2006-04-04 17:07:14.171 53,53,20,00,00,00,02,65,6E,
. 2006-04-04 17:07:14.171 Discarding reserved response
. 2006-04-04 17:07:14.171 Waiting for another 4 bytes
. 2006-04-04 17:07:14.171 Looking for incoming data
. 2006-04-04 17:07:14.181 Select result is 1
. 2006-04-04 17:07:14.181 Received 4 bytes
. 2006-04-04 17:07:14.181 Received 36 bytes
< 2006-04-04 17:07:14.181 Type: SSH_FXP_STATUS, Size: 36, Number: 1795
< 2006-04-04 17:07:14.181 65,00,00,07,03,00,00,00,04,00,00,00,11,54,68,65,20,66,69,6C,65,20,65,78,69,
< 2006-04-04 17:07:14.181 73,74,73,2E,20,00,00,00,02,65,6E,
< 2006-04-04 17:07:14.181 Status/error code: 4, Message: 1795, Server: The file exists. , Language: en
> 2006-04-04 17:07:14.181 Type: SSH_FXP_LSTAT, Size: 36, Number: 2055
> 2006-04-04 17:07:14.181 07,00,00,08,07,00,00,00,17,43,3A,2F,43,3A,2F,43,3A,2F,43,3A,2F,54,65,73,74,
> 2006-04-04 17:07:14.181 57,69,6E,2E,74,78,74,00,00,00,AD,
. 2006-04-04 17:07:14.181 Sent 40 bytes
. 2006-04-04 17:07:14.181 There are 0 bytes remaining in the send buffer
. 2006-04-04 17:07:14.181 Waiting for another 4 bytes
. 2006-04-04 17:07:14.181 Looking for incoming data
. 2006-04-04 17:07:14.181 Received 42 bytes
< 2006-04-04 17:07:14.181 Type: SSH_FXP_STATUS, Size: 42, Number: 2055
< 2006-04-04 17:07:14.181 65,00,00,08,07,00,00,00,09,00,00,00,17,54,68,65,20,68,61,6E,64,6C,65,20,69,
< 2006-04-04 17:07:14.181 73,20,69,6E,76,61,6C,69,64,2E,20,00,00,00,02,65,6E,
< 2006-04-04 17:07:14.181 Status/error code: 9, Message: 2055, Server: The handle is invalid. , Language: en
* 2006-04-04 17:07:14.181 (ETerminal) General failure (server should provide error description).
* 2006-04-04 17:07:14.181 Error code: 4
* 2006-04-04 17:07:14.181 Error message from server (en): The file exists.
* 2006-04-04 17:07:14.181 Request code: 3
. 2006-04-04 17:07:14.181 Asking user:
. 2006-04-04 17:07:14.181 Cannot create remote file 'C:/C:/TestWin.txt'. ("General failure (server should provide error description).
. 2006-04-04 17:07:14.181 Error code: 4
. 2006-04-04 17:07:14.181 Error message from server (en): The file exists.
. 2006-04-04 17:07:14.181 Request code: 3")
* 2006-04-04 17:07:14.181 (EScpSkipFile) Cannot create remote file 'C:/C:/TestWin.txt'.
* 2006-04-04 17:07:14.181 General failure (server should provide error description).
. 2006-04-04 17:07:14.181 Listing directory "C:".
> 2006-04-04 17:07:14.181 Type: SSH_FXP_OPENDIR, Size: 11, Number: 2315
> 2006-04-04 17:07:14.181 0B,00,00,09,0B,00,00,00,02,43,3A,
. 2006-04-04 17:07:14.181 Sent 15 bytes
. 2006-04-04 17:07:14.181 Received 13 bytes
< 2006-04-04 17:07:14.181 Type: SSH_FXP_HANDLE, Size: 13, Number: 2315
< 2006-04-04 17:07:14.181 66,00,00,09,0B,00,00,00,04,00,00,00,00,
> 2006-04-04 17:07:14.181 Type: SSH_FXP_READDIR, Size: 13, Number: 2572
> 2006-04-04 17:07:14.181 0C,00,00,0A,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:07:14.181 Sent 17 bytes
. 2006-04-04 17:07:14.181 Received 1363 bytes
< 2006-04-04 17:07:14.181 Type: SSH_FXP_NAME, Size: 1363, Number: 2572
< 2006-04-04 17:07:14.181 68,00,00,0A,0C,00,00,00,19,00,00,00,0B,24,4D,46,43,4C,69,63,65,6E,73,65,00,
< 2006-04-04 17:07:14.181 00,02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4A,B4,00,00,00,00,40,
< 2006-04-04 17:07:14.181 EC,05,6C,00,00,00,00,41,11,4F,55,00,00,00,10,00,00,00,04,2E,72,6E,64,00,00,
< 2006-04-04 17:07:14.181 02,39,01,00,00,00,00,00,00,04,00,00,00,00,00,42,AD,DF,A2,00,00,00,00,42,4C,
< 2006-04-04 17:07:14.181 49,50,00,00,00,00,42,4D,5F,0B,00,00,00,10,00,00,00,0F,41,62,61,74,49,6E,73,
< 2006-04-04 17:07:14.181 74,61,6C,6C,2E,6C,6F,67,00,00,02,39,01,00,00,00,00,00,00,00,DF,00,00,00,00,
< 2006-04-04 17:07:14.181 42,AD,DF,A2,00,00,00,00,40,E5,E5,22,00,00,00,00,41,6D,8A,7C,00,00,00,10,00,
< 2006-04-04 17:07:14.181 00,00,0A,61,72,63,6C,64,72,2E,65,78,65,00,00,02,39,01,00,00,00,00,00,02,4C,
< 2006-04-04 17:07:14.181 00,00,00,10,00,00,00,07,69,6E,65,74,73,76,63,00,00,02,39,02,00,00,00,00,00,
< 2006-04-04 17:07:14.181 00,00,00,00,00,00,00,44,32,4A,C4,00,00,00,00,40,E5,73,97,00,00,00,00,40,E5,
< 2006-04-04 17:07:14.181 DF,8A,00,00,00,10,00,00,00,06,49,4F,2E,53,59,53,00,00,02,39,01,00,00,00,00,
< 2006-04-04 17:07:14.181 00,00,00,00,00,00,00,00,40,E5,73,F4,00,00,00,00,40,E5,73,F4,00,00,00,00,40,
< 2006-04-04 17:07:14.181 E5,73,F4,00,00,00,17,00,00,00,0B,6A,64,6B,31,2E,33,2E,31,5F,30,34,00,00,02,
< 2006-04-04 17:07:14.181 39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4A,C4,00,00,00,00,40,EC,5C,
< 2006-04-04 17:07:14.181 5A,00,00,00,00,40,EC,5C,5F,00,00,00,10,
> 2006-04-04 17:07:14.181 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
> 2006-04-04 17:07:14.181 0C,00,00,0B,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:07:14.191 Select result is 1
. 2006-04-04 17:07:14.191 Received 4 bytes
. 2006-04-04 17:07:14.191 Received 1356 bytes
< 2006-04-04 17:07:14.191 Type: SSH_FXP_NAME, Size: 1356, Number: 2828
< 2006-04-04 17:07:14.191 68,00,00,0B,0C,00,00,00,19,00,00,00,07,6C,6F,67,2E,74,78,74,00,00,02,39,01,
< 2006-04-04 17:07:14.191 00,00,00,00,00,04,EB,FA,00,00,00,00,43,51,CC,4B,00,00,00,00,43,51,CC,45,00,
< 2006-04-04 17:07:14.191 00,00,00,43,51,CC,4B,00,00,00,10,00,00,00,04,4C,4F,47,53,00,00,02,39,02,00,
< 2006-04-04 17:07:14.191 00,00,00,00,00,00,00,00,00,00,00,44,2F,76,A6,00,00,00,00,40,E5,DE,F7,00,00,
< 2006-04-04 17:07:14.191 00,00,40,E5,DE,F7,00,00,00,10,00,00,00,09,4D,53,44,4F,53,2E,53,59,53,00,00,
< 2006-04-04 17:07:14.191 02,39,01,00,00,00,00,00,00,00,00,00,00,00,00,40,E5,73,F4,00,00,00,00,40,E5,
< 2006-04-04 17:07:14.191 00,00,40,FD,3F,EE,00,00,00,00,40,FD,3F,EE,00,00,00,10,00,00,00,0B,54,65,73,
< 2006-04-04 17:07:14.191 74,57,69,6E,2E,74,78,74,00,00,02,39,01,00,00,00,00,00,00,00,0B,00,00,00,00,
< 2006-04-04 17:07:14.191 44,32,E9,2C,00,00,00,00,44,32,E9,7D,00,00,00,00,44,32,E8,99,00,00,00,10,00,
< 2006-04-04 17:07:14.191 00,00,0C,74,73,6D,6C,76,73,61,63,61,63,68,65,00,00,02,39,02,00,00,00,00,00,
< 2006-04-04 17:07:14.191 00,00,00,00,00,00,00,44,32,4B,2C,00,00,00,00,42,BB,E0,8D,00,00,00,00,43,50,
< 2006-04-04 17:07:14.191 DA,DB,00,00,00,10,
> 2006-04-04 17:07:14.191 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
> 2006-04-04 17:07:14.191 0C,00,00,0C,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:07:14.191 Sent 17 bytes
. 2006-04-04 17:07:14.191 There are 0 bytes remaining in the send buffer
. 2006-04-04 17:07:14.191 Waiting for another 4 bytes
. 2006-04-04 17:07:14.191 Looking for incoming data
. 2006-04-04 17:07:14.191 Received 564 bytes
< 2006-04-04 17:07:14.191 Type: SSH_FXP_NAME, Size: 564, Number: 3084
< 2006-04-04 17:07:14.191 68,00,00,0C,0C,00,00,00,0A,00,00,00,0A,74,73,6D,5F,69,6D,61,67,65,73,00,00,
< 2006-04-04 17:07:14.191 02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,2C,00,00,00,00,42,72,
< 2006-04-04 17:07:14.191 9B,BE,00,00,00,00,42,72,9B,BE,00,00,00,10,00,00,00,0C,55,6E,69,6E,73,74,52,
< 2006-04-04 17:07:14.191 41,2E,6C,6F,67,00,00,02,39,01,00,00,00,00,00,00,03,72,00,00,00,00,42,AD,DF,
< 2006-04-04 17:07:14.191 A2,00,00,00,00,41,EA,7B,32,00,00,00,00,41,EA,7B,32,00,00,00,10,00,00,00,05,
< 2006-04-04 17:07:14.191 75,74,69,6C,73,00,00,02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,
< 2006-04-04 17:07:14.191 2D,00,00,00,00,40,E5,2B,A3,00,00,00,00,40,E5,DE,F7,00,00,00,10,00,00,00,05,
< 2006-04-04 17:07:14.191 55,58,4C,6F,67,00,00,02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,
< 2006-04-04 17:07:14.191 2D,00,00,00,00,40,E5,D2,ED,00,00,00,00,40,E5,D2,FD,00,00,00,10,00,00,00,0A,
< 2006-04-04 17:07:14.191 56,53,68,65,6C,6C,42,6B,75,70,00,00,02,39,02,00,00,00,00,00,00,00,00,00,00,
< 2006-04-04 17:07:14.191 00,00,44,32,4B,2D,00,00,00,00,42,3D,88,A2,00,00,00,00,44,22,B9,AB,00,00,00,
< 2006-04-04 17:07:14.191 10,00,00,00,19,56,53,68,65,6C,6C,43,6F,6E,6E,65,63,74,69,6F,6E,4C,69,6D,69,
< 2006-04-04 17:07:14.191 74,2E,72,74,66,00,00,02,39,01,00,00,00,00,00,18,B0,A0,00,00,00,00,43,9F,56,
< 2006-04-04 17:07:14.191 88,00,00,00,00,43,9F,32,D1,00,00,00,00,43,9F,32,D1,00,00,00,10,00,00,00,14,
< 2006-04-04 17:07:14.191 56,53,68,65,6C,6C,53,72,76,53,74,6F,70,70,65,64,2E,72,74,66,00,00,02,39,01,
< 2006-04-04 17:07:14.191 00,00,00,00,00,18,B0,A0,00,00,00,00,44,20,69,2F,00,00,00,00,43,9F,33,49,00,
< 2006-04-04 17:07:14.191 00,00,00,43,9F,33,49,00,00,00,10,00,00,00,07,77,65,73,2E,74,78,74,00,00,02,
< 2006-04-04 17:07:14.191 39,01,00,00,00,00,00,00,00,03,00,00,00,00,44,32,E9,73,00,00,00,00,42,5E,D3,
< 2006-04-04 17:07:14.191 B0,00,00,00,00,42,5E,D3,B8,00,00,00,10,00,00,00,05,57,49,4E,4E,54,00,00,02,
< 2006-04-04 17:07:14.191 39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,E4,5E,00,00,00,00,40,E5,2A,
< 2006-04-04 17:07:14.191 C6,00,00,00,00,44,1D,7F,57,00,00,00,10,00,00,00,06,57,69,6E,53,43,50,00,00,
< 2006-04-04 17:07:14.191 02,39,02,00,00,00,00,00,00,00,00,00,00,00,00,44,32,4B,2D,00,00,00,00,40,FE,
< 2006-04-04 17:07:14.191 C7,52,00,00,00,00,40,FE,C7,56,00,00,00,10,
> 2006-04-04 17:07:14.191 Type: SSH_FXP_READDIR, Size: 13, Number: 3340
> 2006-04-04 17:07:14.191 0C,00,00,0D,0C,00,00,00,04,00,00,00,00,
. 2006-04-04 17:07:14.191 Received 44 bytes
< 2006-04-04 17:07:14.191 Type: SSH_FXP_STATUS, Size: 44, Number: 3340
< 2006-04-04 17:07:14.191 65,00,00,0D,0C,00,00,00,01,00,00,00,19,54,68,65,72,65,20,61,72,65,20,6E,6F,
< 2006-04-04 17:07:14.191 20,6D,6F,72,65,20,66,69,6C,65,73,2E,20,00,00,00,02,65,6E,
< 2006-04-04 17:07:14.191 Status/error code: 1
> 2006-04-04 17:07:14.191 Type: SSH_FXP_CLOSE, Size: 13, Number: 3588
> 2006-04-04 17:07:14.191 04,00,00,0E,04,00,00,00,04,00,00,00,00,
. 2006-04-04 17:07:14.612 Session upkeep
. 2006-04-04 17:07:14.612 Select result is 1
. 2006-04-04 17:07:14.612 Detected incoming data while idle
. 2006-04-04 17:07:15.113 Session upkeep
. 2006-04-04 17:07:15.113 Select result is 0
. 2006-04-04 17:07:15.613 Session upkeep
. 2006-04-04 17:07:29.133 Select result is 0
. 2006-04-04 17:07:29.633 Session upkeep
. 2006-04-04 17:07:29.633 Select result is 0
. 2006-04-04 17:07:30.134 Session upkeep
. 2006-04-04 17:07:30.134 Select result is 0
. 2006-04-04 17:07:30.635 Session upkeep
. 2006-04-04 17:07:30.635 Select result is 0
. 2006-04-04 17:07:31.136 Session upkeep
. 2006-04-04 17:07:31.136 Select result is 0
kshv
debug - 2 logs
In the above logs it is saying it is not able to copy to the location
Why is C:/C:/ repeated twice ?
Re: debug - 2 logs
It because path not starting with slash is considered relative in SFTP protocol. So WinSCP concatenates it with current working directory. The Vandyke server must expect this (as it's more or less its fault) and can handle that correctly (or at least it usually does :-))
kshv
Invalid Handle
Any Ideas as to why windows UpdateRollup1 sp for windows 2000 sp4(KB891861) is resulting in "invalid handle" error message.
Re: Invalid Handle
Sorry, no idea :-(
Re: Invalid Handle
kshv wrote:
Can we expect a bug fix for this anytime in the near future?
Sorry, you can hadly expect a fix, when I have no reason to think it's bug of WinSCP.
KXD
SFTP Version
I was having a similar issue using a different SFTP client communicating with Van Dyke VShell 2.3x when I stumbled upon this post. I found that the problem is VShell is negotiating that it can communicate at SFTP V4 and it CANNOT. I hardcoded in my client to use SFTP V3 and suddenly everything worked.
Iczer
Re: SFTP Version
Thank you so much! I'm using VShell v2.2.2(build 547) with WinSCP v4.0.6, and was getting the following error message when trying to browse directories simply named "In", "Out", and "Log":
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server (en): The handle is invalid.
Request code: 7
Sure enough, editing my session profile under Environment/SFTP, and specifying that the Preferred SFTP protocol version should be: 3 , allowed me to browse them successfully. This has been bugging me for a month, so thanks very much for your comment, KXD.
