Use multiple connections for single transfer not working
nicknick
No matter what I try, using multiple connections for a single transfer does not do anything.
I've turned off the "Preserve timestamp" option, checked the box "Use multiple connections for a single transfer", and set the maximum connection limit to 9.
The site I'm transferring files from uses SFTP.
Is this feature currently working with the SFTP protocol? Are there any other settings I should change to get this working?
Thanks,
-Nick
Re: use multiple connections for single transfer not working
You are transferring a single file only. Did you expect WinSCP to upload chunks of the same file using multiple connections? WinSCP does not support that. WinSCP can only upload different files using parallel connections.
alejandro
One solution I found is using 7-Zip to first split the file in chunks, ideally 9 chunks. If you don't want to compress you can set the compression level to "store", which will split the file super fast. This is also great because 7z has checksum when putting the file back together. Obviously this is only worth it for large files that take some time.
Pueblo7230
Australia
I have been using the 7-zip hack to split large file and doing multiple parallel transfers. Thanks for raising the request to have this in the product. Do we have any estimate of when the request would be released or if it is on the roadmap?
chambm
The maximum size of an S3 PUT request is 5GB. So multipart upload is really mandatory for large files. Thanks for maintaining this great software!
