.NET Assemblies session.SynchronizeDirectories events
cazzoo
cazzoo avatar
France
Dear all,
I recently tried to implement SynchronizeDirectories to a new wpf app I'm building and I'm facing weird issues with events that are acting in a strange way.
The synchronization is working properly in both ways, but the progressbar is not updated during the synchronization itself, only at the end of the process. In short terms, my code is going to eventHandlers but not updating the window itself. Any ideas on that ?
Here is the code I'm using :
ProgressWindow.xaml
<Window x:Class="MyApp.SynchronizationWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        mc:Ignorable="d"
        Title="Mod synchronization" Width="500" WindowStyle="ToolWindow" SizeToContent="Height" WindowStartupLocation="CenterOwner" ResizeMode="NoResize" ShowInTaskbar="False" ContentRendered="Window_ContentRendered">
    <DockPanel>
        <StackPanel DockPanel.Dock="Bottom">
            <StatusBar>
                <StatusBarItem>
                    <TextBlock Name="statusText" />
                </StatusBarItem>
            </StatusBar>
        </StackPanel>
        <StackPanel Margin="0,0,0,5">
            <Label Content="Current File" />
            <Label Name="fileName" Content="" BorderThickness="0" Margin="30,0,10,0" />
            <StackPanel Margin="50,0">
                <StackPanel Orientation="Horizontal">
                    <Label Content="File progress :" />
                    <Label Name="filePercentage" Content="0%" />
                </StackPanel>
                <ProgressBar Name="fileProgress" Height="15" Foreground="#FF01D328" />
                    <Label Content="Overall progress :" />
                    <Label Name="overallPercentage" Content="0%" />
                </StackPanel>
                <ProgressBar Name="overallProgress" Height="15" Foreground="#FF0160D3" />
            </StackPanel>
        </StackPanel>
    </DockPanel>
</Window>
ProgressWindow.xaml.cs
using MyApp;
using System;
using System.Collections.Generic;
using System.IO;
using System.Text;
using System.Windows;
using WinSCP;
using System.Linq;
namespace MyApp
    /// <summary>
    /// Interaction logic for SynchronizationWindow.xaml
    /// </summary>
    public partial class SynchronizationWindow : Window
        private string _lastFileProcessed;
        private int _countFilesToSynchronize;
        private int _countFilesProcessed;
        private Action _selectedAction;
        public enum Action
            DOWNLOAD,
            UPLOAD
        public SynchronizationWindow(Action selectedAction)
            InitializeComponent();
            ResetComponents();
            _selectedAction = selectedAction;
        private void ResetComponents()
            _countFilesToSynchronize = 0;
            _countFilesProcessed = 0;
            statusText.Text = null;
            fileName.Content = null;
            filePercentage.Content = "0%";
            fileProgress.Value = 0;
            overallPercentage.Content = "0%";
            overallProgress.Value = 0;
        private void SynchronizeToRemote()
            try
                // Setup session options
                    Protocol = Protocol.Sftp,
                    HostName = Settings.Default.RepositoryUrl,
                    UserName = Settings.Default.RepositoryName,
                    Password = Settings.Default.RepositoryPassword,
                    SshPrivateKeyPath = Settings.Default.RepositoryPrivateKeyPath,
                    PrivateKeyPassphrase = Settings.Default.RepositoryPrivateKeyPassphrase,
                    GiveUpSecurityAndAcceptAnySshHostKey = true
                    // Will continuously report progress of synchronization
                    session.FileTransferred += FileTransferred;
                    // Will continuously report progress of transfer
                    session.FileTransferProgress += SessionFileTransferProgress;
                    // Connect
                    session.Open(sessionOptions);
                    string localPath = Path.Combine("C:\\test");
                    string remotePath = Path.Combine(Settings.Default.RepositoryStoragePath, "test");
                    if (!session.FileExists(remotePath))
                        session.CreateDirectory(remotePath);
                    HashSet<string> filesToSynchronize = new HashSet<string>(Directory.GetFiles(localPath, "*.*", SearchOption.AllDirectories).ToList());
                    _countFilesToSynchronize = filesToSynchronize.Count;
                    SynchronizationResult synchronizationResult;
                    synchronizationResult =
                        session.SynchronizeDirectories(SynchronizationMode.Remote, localPath, remotePath, true);
                    // Throw on any error
                    synchronizationResult.Check();
                    StringBuilder failedFiles = new StringBuilder();
                    foreach (TransferEventArgs failedFile in synchronizationResult.Failures)
                        failedFiles.AppendLine(string.Format("{0}", failedFile.FileName));
                    if (failedFiles.Length > 0)
                        MessageBox.Show(failedFiles.ToString(), "Error uploading files.");
                    if (synchronizationResult.IsSuccess)
                        overallPercentage.Content = string.Format("{0:P0}", 1);
                        overallProgress.Value = 100;
                        statusText.Text = "Operation succeeded.";
            catch (Exception ex)
                Console.WriteLine("Error: {0}", ex);
        private void SynchronizeToLocal()
            try
                    // Connect
                        MessageBox.Show(string.Format("The mod [{0}] doesn't exist in the remote repository [{1}].", Mod.Name, Settings.Default.RepositoryStoragePath));
                        return;
                    if (!Directory.Exists(localPath))
                        Directory.CreateDirectory(localPath);
                    RemoteDirectoryInfo remoteDirectoryInfo = session.ListDirectory(remotePath);
                    _countFilesToSynchronize = remoteDirectoryInfo.Files.Count;
                        session.SynchronizeDirectories(SynchronizationMode.Local, localPath, remotePath, true);
                        MessageBox.Show(failedFiles.ToString(), "Error downloading files.");
        private void FileTransferred(object sender, TransferEventArgs e)
            string returnMessage = string.Empty;
            if (e.Error == null)
                returnMessage = $"Upload of {e.FileName} succeeded";
            else
                returnMessage = $"Upload of {e.FileName} failed: {e.Error}";
            if (e.Chmod != null)
                if (e.Chmod.Error == null)
                    returnMessage = $"Permissions of {e.Chmod.FileName} set to {e.Chmod.FilePermissions}";
                else
                    returnMessage = $"Setting permissions of {e.Chmod.FileName} failed: {e.Chmod.Error}";
            else
                returnMessage = $"Permissions of {e.Destination} kept with their defaults";
            if (e.Touch != null)
                if (e.Touch.Error == null)
                    returnMessage = string.Format("Timestamp of {0} set to {1}", e.Touch.FileName, e.Touch.LastWriteTime);
                else
                    returnMessage = string.Format("Setting timestamp of {0} failed: {1}", e.Touch.FileName, e.Touch.Error);
            else
                // This should never happen during "local to remote" synchronization
                returnMessage = string.Format("Timestamp of {0} kept with its default (current time)", e.Destination);
            Console.WriteLine(returnMessage);
            statusText.Text = returnMessage;
            UpdateOverallProgress();
        private void UpdateOverallProgress()
            _countFilesProcessed++;
            double currentOverallPercentage = (double)_countFilesProcessed / _countFilesToSynchronize;
            overallPercentage.Content = string.Format("{0:P0}", currentOverallPercentage);
            overallProgress.Value = currentOverallPercentage * 100;
        private void SessionFileTransferProgress(object sender, FileTransferProgressEventArgs e)
            // New line for every new file
            if (_lastFileProcessed != null && _lastFileProcessed != e.FileName)
                fileName.Content = String.Format("File [{0}] processed.", e.FileName);
            // Print transfer progress
            string percentage = String.Format("{0:P1}", e.FileProgress);
            filePercentage.Content = percentage;
            fileProgress.Value = e.FileProgress * 100;
            // Remember a name of the last file reported
            _lastFileProcessed = e.FileName;
        private void Window_ContentRendered(object sender, EventArgs e)
            switch (_selectedAction)
                case Action.DOWNLOAD:
                    SynchronizeToLocal();
                    break;
                case Action.UPLOAD:
                    SynchronizeToRemote();
                    break;
Thanks in advance for any hints.
Regards,
Caz
Re: .NET Assemblies session.SynchronizeDirectories events
I do not know WPF, but I assume that as with WinForms, you have to run lenghty operations on a background thread, not on GUI thread.
See an example for WinForms and VB.NET at:
https://stackoverflow.com/q/33012517/850848
Or this WPF question with a link to a generic question (not about WinSCP):
https://stackoverflow.com/q/43364376/850848
