Search Folders / foreach loop upload
JamesM
Hi guys
I'd like to mirror the powershell command:
foreach ($folder in $folderarray) {
Copy-Item "D:\Users\username\*\*\*\$folder\files\*" -Destination
"D:\Users\username\Desktop\temp\" -Recurse
in a way that instead of moving files from one local folder to another the files are moved to an SFTP (the SFTP session is working fine and uploading files is not a problem in general.)
This is what I'd attempted to do:
$session.PutFiles("D:\Users\username\*\*\*\$folder\files\*", "/NewRelease/$folder/", $False, $transferOptions)
But this set up doesn't work in the same way, could someone please tell me I can set this up correctly?
JamesM
Hi Martin
Thanks for your response. Good to know that WinSCP doesn't support file masks in that way.
What I did was create an array of the different folder names and put the initial ForEach loop inside another of this array, it seemed to do the trick!
Cheers
