WinSCP using script to SFTP to Cygwin + task scheduler
Madcliker08
I am trying to SFTP from WinSCP to Cygwin into a sub-directory in the users home folder.
I want the file being sent to go into a subdirectory within the /home/user folder.
I do have the users locked int their home directory as in they can't back out, but they can create new subdirectories
Here is what I am using at the moment in my script. I have tried adding cd,lsd you name it, between open and put commands, nothing works.
open sftp://user:**********@1.1.1.1/
put c:\script\5.txt
I can't get the file to go into any other directory within the users' home.
I would like the file to go into user\FTP
Thank you in advance!
Re: WinSCP using script to SFTP to Cygwin + task scheduler
Can you upload the files in WinSCP GUI?
This should work, if I understand your problem:
put c:\script\5.txt /user/FTP/
