Generate script not available
kaplan71
Hello --
The generate script option in the Commander GUI interface has become unavailable, and I wanted to know how can I get it back?
Thanks.
Reply with quote E-mail
Re: Generate script not available
What does it mean "has become unavailable"? It's not there anymore? Or is it disabled?
The command is there always (if you use a recent version of WinSCP). It's disabled only, if you have no connection open.
kaplan71
Hello --
When I do a drag and drop of the selected files and folders, the contents immediately start to get copied over rather than my being prompted, and there being the option to generate a script within the dropdown menu.
kaplan71 wrote:
Hello --
OK, you must have disabled confirmations of drag&drop operations.
Either enable it again:
https://winscp.net/eng/docs/ui_pref_environment
Or use menu or keyboard shortcut instead of drag&drop.
