How to exclude directories during a get
KTGOPS1
I have automated a sftp file and directory download process through a batch file. There is one directory one the server I do not need to download but I can not figure out how to exclude that directory. I could download it and delete it but it is a huge folder that doesn't need to be pulled down. How can I exclude the folder. Here is my batch file now.
I am using winscp version 5.11.2
This is running on Windows Server 2012 R2
There is a folder in this directory on the server I should not download. /home/customer/data/%year%/%month%/%day%
@echo off
Set CurrentDate=%date:~4,2%-%date:~7,2%-%date:~10,4%
Set Year=%date:~10,4%
Set Month=%date:~4,2%
Set Day=%date:~7,2%
if not exist D:\backups\Software\%CurrentDate% md D:\backups\Software\%CurrentDate%
Echo option echo off>d:\test\downloadscript.txt
Echo option batch on>>d:\test\downloadscript.txt
Echo option confirm off>>d:\test\downloadscript.txt
Echo open sftp://user:password@10.10.10.10>>d:\test\downloadscript.txt
Echo lcd "D:\Backups\Software\%CurrentDate%">>d:\test\downloadscript.txt
Echo cd /home/customer/data/%year%/%month%/%day%>>d:\test\downloadscript.txt
Echo get *.*>>d:\test\downloadscript.txt
Echo exit>>d:\test\downloadscript.txt
"C:\Program Files (x86)\WinSCP\Winscp.com" /script=d:\test\downloadscript.txt
C:\Progra~1\7-Zip\7z a -r D:\backups\Software\%currentDate%.7z D:\backups\Software\%CurrentDate%\*
RD /S /Q D:\backups\Software\%currentDate%
del downloadscript.txt
KTGOPS1
Re: How to exclude directories during a get
Thank you very much. This worked. Below is what my new txt file looks like. Was not working at first until I had to add the / after the l1. L1 is the folder I was excluding. Works great now. Thanks again.
option echo off
option batch on
lcd "D:\Backups\Software\12-07-2017"
cd /home/customer/data/2017/12/07
get *.* -filemask=|/home/customer/data/2017/12/07/l1/
That's correct. Note that my exclude path also ends with a slash.
eghali
Hello, I'm trying the following:
get ""/d/export"" -filemask=""/*/*/*/etlexpmx_BCF_*.xml.gz>2D;/*/*/*/etlexpmx_ETP_*.xml.gz>2D;|/transfer/;""
to exclude "transfer" folder but still it's including it in the download, what am I missing?
The /transfer/ works, only if transfer is in the root folder. If not, use just transfer/ (or the actual absolute path to the folder). If you still have problems, please post a session log file.
