!& and "Filename Modification" Conflict with Custom Commands
Bill_Fields
Portland, OR
When the "Replace" Filename modification is enabled in "Transfer settings", the files listed in !& do not match the temporary local filenames retrieved from the remote source.
Which causes any custom command that needs to work with these temp files to fail with "file not found" since the local temp filenames don't match the filenames listed in !&
