WinSCP uploaded file renamed to ^
question
WinSCP uploaded file gets renamed to ^.
If i upload the same file manually it works, same thing with command line.
When i create a batch script with WinSCP and i iuse it, then the file gets renamed, but why?
@echo off
/log="C:\Temp\WinSCP log\WinSCP.log" /ini=nul ^
/command ^
"open ftpes://xxx/" ^
"put -latest "x:\*" ^
"exit"
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
question
Also when i look at the log, clearly i can see that correct file is selected, but why is it renamed?
File: 'X:\test.csv'
Copying 'X:\test.csv" to remote directory started.
STOR ^
150 Opening data channel for file upload to server of "/^"
226 Successfully transferred "/^"
Transfer done: 'X:\test.csv' => '/^' [5]
Re: WinSCP uploaded file renamed to ^
You have quotes wrong.
Correct syntax is either:
"put -latest ""x:\*""" ^
Or simply (as there are no spaces in the path):
"put -latest x:\*" ^
