Directorymask problem
Jaroslav Vrbka
Dear all,
there is an option to download only directories older than, for example, 3 days?
At source are placed only directories like
2017-11-26T0630+0000
2017-11-25T0630+0000
2017-11-24T0630+0000
2017-11-23T0630+0000
I want to download only the 3 youngest.
If I use the options below, I will not download any directory.
Dim transferOptions As New TransferOptions
transferOptions.TransferMode = TransferMode.Binary
transferOptions.PreserveTimestamp = False
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off
transferOptions.FileMask = "*/<3D"
If I use the options transferOptions.FileMask = "*/" I will download all directory.
Is there any possibility to reach my request using a filemask options?
If not how I can achieve it?
Thank you very much for your help
Jaroslav
Re: Directorymask problem
As these last modification timestamps or directory names?
Sorry for late answer.
The above are directory names.
The modification timestamps are similar.
26.11.2017 7:30:25
25.11.2017 7:30:36
Time constraints do not work for folders.
But you can easily code the same in VB.NET:
Dim newFolders As IEnumerable(Of RemoteFileInfo) =
    session.ListDirectory(sourceRemotePath).Files.Where(
        Function(fileInfo) fileInfo.LastWriteTime >= Date.Now.AddDays(-3))
For Each newFolder In newFolders
    session.GetFiles(newFolder.FullName, targetLocalPath).Check()
Next
Next
Jaroslav wrote:
Thanks your your answer.
I had to modify the code slightly so that the contents of the 3 downloaded directories were stored in separate directories and not overwritten in the root.
Below is a modified function code
Jaroslav
    session.ListDirectory(sourceRemotePat).Files.Where(
    If Not newFolder.FullName = "/." Then
        session.GetFiles(newFolder.FullName, targetLocalPath & "\" & newFolder.FullName.Replace("/", "")).Check()
    End If
Next
