Problem with Unicode in the WinSCP internal editor
there is a Problem with one Unicode character with the WinSCP internal editor.
My workaround:
  • display the character with the HTML hexadecimal code in a webbrowser.
  • copy&paste the character into OpenOffice Calc.
  • copy&paste the character into Notepad++
  • copy&paste the character into the WinSCP internal editor
than, the Unicode character "1D5BC" don't display, but a range of 1023 other characters displaying correctly.
HTML is UTF-8
<html lang="en">
<head>
<meta charset="UTF-8">
OpenOffice import with Unicode (UTF-8)
Notepad++ is set UTF-8
WinSCP internal editor encoding is set UTF-8
When I edit the *.html file in Notepad++ local and upload it, there is no problem with this character.
Re: Problem with Unicode in the WinSCP internal editor
Issue 1580 – Support wider range of Unicode characters in internal editor
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
