CWD cmd failed: EDC5129I No such files or directory (z/OS)
TorbenRy
When I connect to z/OS I get this error: CWD cmd failed: EDC5129I No such files or directory (z/OS)
This is content of my "Remote Directory" in the Site Settings, /'<username>.'.
I try to list my Non-UNIX files (PDS).
Can you tell me the syntax for the "Remote Directory" for PDS files.
I'm using WinSCP version 5.11.2 (build 7781)
TIA
Re: CWD cmd failed: EDC5129I No such files or directory (z/OS)
TorbenRy
Did you get the attached file?
  • guser1@ftps.plex09.xyz.com.log (8.96 KB, Private file)
Sorry for my late reply.
So what if you put just 'guser1.' to the remote directory path (no lead slash)?
Sorry, I do not have an MVS server for testing, so I cannot give you a definitive answer.
Please attach a log file for the new tests in any case.
TorbenRy
Then it looks fine the first time (just realised that). When I connect next time I get the error message again. And I can see that the Directories tab is changed to /'guser1.'.
Now I found the problem, I think. When "Remember last used directory" is enabled you update the Remote directory field and put a / in front.
So when I disabled that feature I can use the connection without error messages.
A very strange thing is that when I try to go up in the structure I always are send to / no matter where I am in the non UNIX structure.
TorbenRy
Did you find anything in the log?
Regarding what? I've understood that you have resolved your problem.
TorbenRy
Two things:
1. It would be nice for "Remember last used directory" to work in non Unix structure.
2. It is a problem that when you go one level up in non Unix you end up in /. If I'm in User1.u.jcl and go one level up it should take me to User1.u and not to / in USS.
OK, understood. Will consider that.
