synchronizing two directories at once
stevante
the sychronize directory feature works very nicely but i need to be able to have it update 2 directories at once. i can do it by highlighting two sub-directories within the same directory and checking "selected files only", but i need to do it with directories in totally different directory trees. is this possible?
You can run two instances of WinSCP. Or you can "synchronize" common root of the two directories and use exclude mask to exclude all directories except the two, if it is feasible.
