winsp.com fails
Xeenych
winsp.com fails
On a newly installed Win7 Pro I run winsp.com with the following:
winscp.com /script=winscpscript.txt
==winscpscript.txt==
option batch abort
# Connect to FTP server using a password
open sftp://user:pass@178.20.43.138:45678/ -rawsettings ProxyMethod=2 ProxyHost=127.0.0.1 ProxyPort=9050
# Upload file
cd /var/www/map/
put -delete 03-Osme\*.* /var/www/map/
# Disconnect
close
This worked perfectly before I reinstalled Win7 to corprate version.
winscp.com produces the following (looks like stack overflow):
D:\10 - mapexport>echo off
batch abort
reconnecttime 120
confirm off
Euo na?aa?Е
Ioeaea naoe: niaaeiaiea n "178.20.43.138" ioeeiiaii.
DIRECT CONNECTION FAILED
USING PROXY
batch abort
reconnecttime 120
confirm off
Euo na?aa?Е
Niaaeiy?nu n na?aa?iiЕ
AooaioeoeeaoeyЕ
I?iaie?eou iiaee??aiea e iaecaanoiiio na?aa?o e aiaaaeou aai ee?? a eyo?
Ee?? oinoa na?aa?a ia iaeaai a eyoa. Iaeucy aa?aioe?iaaou, ?oi yoi oio naiue na?
aa?, eioi?ue aai io?ai.
Ioia?aoie ee??a na?aa?a ssh-ed25519:
ssh-ed25519 256 e8:5b:37:b8:61:dc:81:5a:3a:f9:4a:da:79:83:5b:cf
Anee au aiaa?yaoa yoiio oinoo, ia?ieoa лAa╗. Aey iiaee??aiey aac aiaaaeaiey ee??
a oinoa a eyo ia?ieoa лIao╗. ?oiau i?a?aaou iiaee??aiea, ia?ieoa лIoiaia╗.
In scripting, you should use a -hostkey switch to configure the expected host ke
y.
(A)a, (I)ao, (I)oiaia (0 n), (E)iie?iaaou ee??: Ioiaia
Ee?? na?aa?a ia i?iaa?yeny!
Ioia?aoie ee??a oinoa Ч ssh-ed25519 256 e8:5b:37:b8:61:dc:81:5a:3a:f9:4a:da:79:8
3:5b:cf.
Xeenych
Update.
Win7 is russian. Unreadable text is in russian, and it asks to press "Д" for Yes, but pressing Д,д,Y,y or any other key except "esc" doesn't do anything.
I reinstalled winscp without transaltion. All text now is in english. Winsp asks to confirm host key and pressing "y" works.
I tried the latest 5.11.2 and some older versions around 5.5
Usually I run via command-file
Printing commands directly in winspc.com produces the same result.
There is something with russian transalation or character encoding.
I have Win7 Pro russian.
I tried to set default codepage for non-unicode programs to engish and to russian. It didn't help.
The outuput changed from "iaie?eou iiaee??aiea e iaecaanoiiio na?aa?" to "????????" but keyboard still didn't work.
OK, but where do you put/type that command-line?
This bug with "keyboard" has been added to the tracker:
https://winscp.net/tracker/1573
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Actually, on Windows 7, you may have a "Raster fonts" selected as the default in console windows. Make sure you select "Consolas" or "Lucida Console" instead.
