Winscp transfer event args into a log file in Powerhsell
seanfaria
Miami
I am new to this so forgive me if this is a stupid question.
I have completed my script but I don't understand why this is happening.
Powershell scripts:
Question 1:
Works perfectly:
# Print results
Write-Host ("Successful upload of {0} " -f $transfer.FileName)
Write-LogInfo -Message "Successful upload of $transfer " -LogPath $LogpathDir -ToScreen
Doesn't work perfectly:
#Print Results
foreach($synchronization in $synchronizationResult.Uploads)
Write-Host ("Successful upload of {0} " -f $synchronization.FileName)
Write-LogInfo -Message "Successful upload of $synchronization" -LogPath $LogpathDir -ToScreen
Write-LogInfo -Message "Synchronization of InfoDoc folders is complete" -LogPath $LogpathDir -ToScreen
Question 2:
Item 1:
$synchronizationResult =
$session.SynchronizeDirectories(
[WinSCP.SynchronizationMode]::Both, "E:\path1\", "/path2/", $False) ,
Item 2:
The only difference between item 1 and item 2 is the comma after the first set of paths. Why do they yield different results?
Without a comma you get options like uploads, downloads, removals, failures, isSuccess for session.SynchronizeDirectories which I want but stumbled on this by accident. :?:
Reply with quote E-mail
Re: Winscp transfer event args into a log file in Powerhsell
Question 1: What does it mean "Doesn't work perfectly"? For me both code examples do the same. Both log "Successful upload of WinSCP.TransferEventArgs", what does not seem as a useful log entry. But it's as expected. Use the syntax that you have in Write-Host.
Question 2: If you do not consume a function return value, it is piped to the output.
Both your question are generic PowerShell questions. They have nothing to do with WinSCP.
seanfaria
Miami
Sorry about that and i figured it out.
Thank you
