Synchronize remote with local and exclude subdirectories
JanneFiH
I've this directory locally that I'd like to synchronize with a remote server. (I want my remote server to look like the local directory)
/DIR
 -> /A
 -> /B
 -> /C
I would like to exclude subdirectories within A, B and C from being synchronized.
I also have some files in /DIR that I also would like to be excluded from being synchronized. Just files in /A/, /B/ and /C/. I don't want to accidentally delete files or folders on either local or remote.
I don't get the .bat-file to start. Can anyone please check what I'm doing wrong? It doesn't post to the log file.
    "open ftp://USER:PASSWORD@IP:PORT/ -passive=0" ^
    "cd /DIR/A/" ^
    "lcd C:\A\ ^
    "synchronize remote -delete -nopermissions -transfer=binary -filemask="|*/" * ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Thanks in advance!
Re: Synchronize remote with local and exclude subdirectories
I'm sorry. I censored myself when writing the topic.
@echo off
  /log="F:\skrivbord\log\WinUPP.log" /ini=nul ^
  /command ^
    "cd /DIR/A/" ^
    "lcd C:\A\ ^
    "exit"
  echo Success
) else (
  echo Error
You are missing some quotes.
Here:
    "lcd C:\A\" ^
And here:
    "synchronize remote -delete -nopermissions -transfer=binary -filemask=""|*/"" * ^
See https://winscp.net/eng/docs/commandline#syntax
Also make sure that the ^'s are the very last characters on their respective lines (there cannot be any space after them).
See Why are some WinSCP scripting commands specified in a batch file not executed/failing?
@echo off
  /command ^
    "cd /DIR/A/" ^
    "lcd C:\A\" ^
    "exit"
  echo Success
) else (
  echo Error
JanneFiH
Thank you for your corrections, Martin!
Now I at least receive an error log. It's written in my native language.
. 2017-10-27 06:09:47.106 Asking user:
. 2017-10-27 06:09:47.106 Fel uppstod när listning av katalog '*'. ("Fel vid hämtning av fillista för ""*\*.*"".","Systemfel. Kod: 123.","Felaktig syntax för filnamn, katalognamn eller volymetikett")
< 2017-10-27 06:09:47.106 Script: Fel uppstod när listning av katalog '*'.
< 2017-10-27 06:09:47.106 Script: Fel vid hämtning av fillista för "*\*.*".
< 2017-10-27 06:09:47.106 Systemfel. Kod: 123.
< 2017-10-27 06:09:47.106 Felaktig syntax för filnamn, katalognamn eller volymetikett
< 2017-10-27 06:09:47.107 Script: Fel uppstod när listning av katalog '*'.
< 2017-10-27 06:09:47.107 Fel vid hämtning av fillista för "*\*.*".
< 2017-10-27 06:09:47.107 Systemfel. Kod: 123.
< 2017-10-27 06:09:47.107 Felaktig syntax för filnamn, katalognamn eller volymetikett
. 2017-10-27 06:09:47.107 Script: Failed
. 2017-10-27 06:09:47.107 Script: Exit code: 1
. 2017-10-27 06:09:47.107 Kopplar ifrån server
Error code 123. It isn't able to fetch file list for "*\*.*"
Please tell me if you would like further translation to be able to see the problem.
OK, there's one more missing quote, and the * should not be there:
    "synchronize remote -delete -nopermissions -transfer=binary -filemask=""|*/""" ^
JanneFiH
Oh my, Mr Hawkeye himself to notice that! It work's really great now! As always, huge thanks for your help, Martin!
