Wrong Last modified date
acoste
I'm using WinSCP script to download files from a ftp server without any problem for one year.
On the remote folder I download the files newer than 1 day using the -filemask=*>1D.
But 1 year after running this script I see that the files from last year (same day) were also downloaded, and when using the GUI interface the last year's files show a Last Modified Date within this current year.
See screenshot attached where the last modified date appears in 2017.
Using the mdtm command from terminal for this same file, it show a correct date in 2016
$ mdtm F__073____1610121821
213 201610286062132
Viewing files with google Chrome the correct Last modified date is showed (2016).
Thanks in advance for your help.
WinSCP 5.11.1
Re: Wrong Last modified date
How do you "view files with google Chrome"?
acoste
I can view filelist in Chrome entering ftp://FT_SERVER:PORT_number in the adress bar.
Please find attached seesion log.
  • session.zip (10.41 KB, Private file)
Description: Session log and screenshot of the file seen with a bad date
Your server behaves rather unusually. I'm afraid you will get the same problem with many other FTP clients. It's just a luck that the Chrome works.
Note that the problem happens only for files created/modified one year and one day in the past. Not for all old files.
