Can't exit from deleted directory
kapela86
Steps to reproduce (tested this only on ssh connection):
  1. Create some directory on server and enter it in WinSCP, for example
    /abc
  2. Remove that directory on server by some other method (I use KiTTY, a fork of PuTTY)
  3. Now in WinSCP try going to parent directory, you will receive an error
    Cannot get real path for '/abc/..'.
    No such file or directory.
    Error code: 2
    Error message from server: No such file
It's probably related to my other bug report, I suspect that going to parent directory forces WinSCP to refresh current directory (which is a really stupid thing to do...)
Re: Can't exit from deleted directory
Well, WinSCP does what the SFTP standard mandates it should do. And it has this unfortunate side effect.
We will consider implementing some kind of a fallback.
WinSCP definitely does not refresh the current directory, when going to the parent folder.
kapela86
Hi, I just checked this with version 5.13 and this bug is still present. Are you planing to do something with this? It's not a high priority bug, but still a bug when looking at it from user perspective.
