synchronize remote -filemask Synchronizing based on a partial filename
untouchable
Hi there
I'm trying to synchronize remote files based on a partial filename.
Filenames always start with pds and then any further letters.
I have tried with:
synchronize remote -filemask="pds*."
But I always get a error
too much parameters for the command.
How is the correct command
thx
Andreas
Re: synchronize remote -filemask Synchronizing based on a partial filename
Your syntax is correct, assuming you are not using some ancient version of WinSCP.
If you get the problem with even the latest version of WinSCP, please attach a full session log file showing the problem.
untouchable
Hi martin
attached you'll find the log
Regards
Andreas
Description: winscp.log
Your problem has nothing to do with the -filemask argument. It's about the spaces in the paths.
You have to enclose the paths with spaces to double quotes:
synchronize remote -filemask="pds*." "M:\Produktedokumentation\Datenblätter\deutsch\01 Motorenoele" "/share/CACHEDEV1_DATA/STRUB-Data/Deutsch/01 Motorenoele/01 Datenblätter"
See https://winscp.net/eng/docs/scripting#quotes
