Using /log and /parameter at the same time not working
cyrusv
PNW
I am trying to call the com interface in a batch file with both /parameter and /log at the same time. Below is what I am encountering:
::Sends files with parameter OK
WinSCP.com /script="%scriptsdir%\put_files.txt" /parameter // "%dailydir%"
::Sends files with out parameter and creates log OK
WinSCP.com /script="%scriptsdir%\put_files.txt" /log="C:\LOGFILE_!Y!M!D.log"
::Sends files OK but doesn't create log
WinSCP.com /script="%scriptsdir%\put_files.txt" /parameter // "%dailydir%" /log="C:\LOGFILE_!Y!M!D.log"
::Fails to send files or create log
WinSCP.com /script="%scriptsdir%\put_files.txt" /log="C:\LOGFILE_!Y!M!D.log" /parameter // "%dailydir%"
Anybody have any ideas? I am running version 5.9.1 of WinSCP. Thanks!
Re: Using /log and /parameter at the same time not working
That's because of the //. It tells WinSCP to treat all following parameters as plain parameters, newer as switches.
Just remove the //.
See https://winscp.net/eng/docs/commandline#two_slashes
This works for me.
