mask issue
gpolyc
VA
mask issue
Hi, I'm new to scripting so this may be a simple question. I'm trying to use the following mask for getting a file: "va_x_co_public_school_dist_(va_x)_comprehensive*". It is a csv file. The file name changes daily after the *. There is always only a single file with the beginning specification in the directory. If I use ".csv" I can find it. Any ideas on why I can't find the file using the mask above? Thanks!
Re: mask issue
