Select column width using winscp.com
pistacho
Hello:
When I use winscp.com to synchronize a remote directory with a local one, it shows one line per file with this format:
veeeery_long_name_truncat |          31 KB |    0,0 KB/s | binary |   0%
The first column shows the file name, but it "only" has 26 characters, which usually truncate some of them.
Is it possible to select or change that column width, so it can show more than 26 characters?
Thank you.
Best regards.
Re: Select column width using winscp.com
No, this is not configurable.
You can see a complete file name in XML log file.
https://winscp.net/eng/docs/logging_xml
Or you can use WinSCP .NET assembly with its Session.FileTransferProgress from a PowerShell script to implement a progress report format you like.
https://winscp.net/eng/docs/library_session_filetransferprogress
https://winscp.net/eng/docs/library_powershell
