Brand New User - How to connect to remote drives?
LorneAKruse
I've managed to login and on the left pane of the commander interface my local drives and files are shown. However I don't know how to connect to the remote server side of the interface on the right pane. I've tried every thing that I can think of without success. Please help a newby. :?
My server OS is openmediavault.
Re: Brand New User - How to connect to remote drives?
I'm not sure I understand. On one hand you write "I've managed to login", on the other, you write "I don't know how to connect".
Maybe a screenshot would help to explain your problem.
Lorne Kruse
This how new I am...How do I do a screenshot?
Lorne Kruse
I'm logged into my server @ 192.168.1.104 but when I click on the remote "root" directory no other directories or files show up; see screenshot.
That probably just means that there are indeed no files.
Do you have any reason to expect any files there?
Lorne Kruse
I thought I put a Folder called Multimedia in through the openmediavault GUI but maybe I did that wrong. Are you able to instruct me how I can do that in the OMV GUI so that it shows in Winscp?
