Optimize connection buffer size
srjones67
I am receiving the message that I have noted in the subject:
Host is not communicating for more than 15 seconds.
Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
Warning: Aborting this operation will close connection!
(A)bort (58 s):
I made what I thought was the proper adjustment but it's still occurring. The transfer completes but I repeatedly get the error. This is the command that I am executing:
"C:\Support\Utils\WinSCP\winscp" /script=C:\Support\Scripts\CorrectAddress\CA_Update_Get.txt /parameter "user:pw" "site.url.com" "/CorrectAddress/Geocoder" "C:\Support\Scripts\CorrectAddress\incoming\Geocoder\" "*.*" /rawconfig SendBuf=0 /loglevel=0 /loglevel=0 /log=C:\Support\Logs\CA_Update_Get_2017-09-15.log
Any help would be appreciated.
srjones67
I'm getting this error with that change: Too many parameters for command 'open'.
This is my open command in CA_Update_Get.txt: open sftp://%1%@%2% -rawconfig SendBuf=0
I did remove the /rawconfig SendBuf=0 from the calling command. If I change -rawconfig SendBuf=0 to -rawsettings SendBuf=0 it seems to work.
Update: -rawconfig on open command yields too many parameters. -rawsettings gives no parameter error but still get try turning off 'Optimize connection buffer size.
Are you using the latest version of WinSCP?
If you are, please attach a full session log file showing the problem (using the latest version of WinSCP).
Vann_the_Red
Eerie Solution?
I found this thread because I was experiencing the exact same problem as the OP. I turned on logging as Martin directed. It immediately started working. No idea why logging the session mattered, but that seems to have done it.
VtR
srjones67
Log File
Here is a log of what is occurring. I'm using WinSCP, Version 5.7.2 (Build 5316).
  • CA_Update_Get_2018-01-17.log (1.36 MB, Private file)
Re: Log File
There's no "Too many parameters for command 'open'" error in the log.
Though actually there cannot be, such error won't be logged (it was a mistake for me to ask for a log file).
So I'm really confused what the log should show. Because it shows successful connect.
Anyway, show us your script and your WinSCP command-line for which the script is failing.
srjones67
"C:\Support\Utils\WinSCP\winscp" /script=C:\Support\Scripts\CorrectAddress\CA_Update_Get.txt /parameter "User:Password" "sftp.url.com" "/CorrectAddress/CAN" "C:\Support\Scripts\CorrectAddress\incoming\CAN\" "*.*" /loglevel=0 /log=C:\Support\Logs\CA_Update_Get_.log
Contents of CA_Update_Get.txt
open sftp://%1%@%2% -rawsettings SendBuf=0
echo on
cd "%3%"
dir
lcd "%4%"
Get "%5%"
lls "%4%"
dir "%3%"
You did not answer my question.
And I'm not getting "Too many parameters for command 'open'" error when running your code.
Though btw, doesn't your username or password contain a space?
