How to restart the session & Upload files in case of exception occurs
Sitakanta
Bangalore, India
Sometimes we get error as- "Session has unexpectedly closed" in between the FTP upload. I want to restart the upload in such situation.
Please help
Description: Session has unexpectedly closed Error
Re: How to restart the session & Upload files in case of exception occurs
It should restart on its own. If it does not, please attach a full session log file showing the problem (using the latest version of WinSCP).
