My GetFiles is working but PutFiles get the following message
rodneylajuan@...
My GetFiles is working but PutFiles get the following message. Please Help
{"Cannot create remote file '/xxxxxxxxxx/Reference/TEST/IN/Warrant.csv'."}
rodneylajuan@gmail.com
Re: My GetFiles is working but PutFiles get the following message
