Where is the "Generate code dialog" ?
alrisk
Hello community!
I need to generate a script for a large data download, but I can not find how to get to the "Generate code dialog".
According to documentation and screenshots it must be here: "Transfer Options Dialog" >> "Transfer Settings" >> "Generate Code", but I can not see it! Is there a hidden button? Do I need an additional plug-in? Is this feature not available in my version?
Re: Where is the "Generate code dialog" ?
Yes, it's possible that this feature not available in your version.
Make sure you are using the latest version of WinSCP.
