unable to drag and drop from remote to local
becca_becca
Hi
I'm using winscp (v5.9.6), commander style gui and my os is win7.
I used to be able to copy files from remote to local and vis versa by dragging and dropping. All of a sudden this has stopped working. I dont get an error message but nothing happens.
I've checked that enable drag and drop is checked in both preferences and transfer settings. I am unaware of any changes that have been made between when it worked and when it didnt (no updates either to windows or winscp that im aware of)
I created a log file too but unable to attach as it seems to think its in use by another program. I've closed winscp but still get this error.
I'd be very grateful for any help.
Re: unable to drag and drop from remote to local
Where exactly are you dragging the files from and to? Remote and local panel of WinSCP? A file panel? Or a directory tree? Or Windows Explorer? A screenshot may help.
kevin_cyndaquil
becca_becca wrote:
Hi
I had the same problem with v5.11.2 on Windows 10 ver 1709 Build 16299.125. I did a complete uninstall and reinstall, and everything is now fine.
