"Get" works - but only for small files
memnon
i use Autoit with Winscp - i use autoit´s run command to use winscp.exe /command to get or put files on our ftp server
i havent any troubles with put at all - does what it should
with get - i get small textfiles - but if i want to get a 8mb exe file i do not get it
it looks the same in the log file of the ftp server but retrieving the file i get disconnect
any clou what i am doing wrong ?
(btw if i use winscp.exe gui it works well)
memnon
and thats the logfile
. 2017-08-02 16:37:34.868 --------------------------------------------------------------------------
. 2017-08-02 16:37:34.868 WinSCP Version 4.2.5 (Build 624) (OS 6.2.9200)
. 2017-08-02 16:37:34.868 Login time: Mittwoch, 2. August 2017 16:37:34
. 2017-08-02 16:37:34.868 Session name: get@WanIP
. 2017-08-02 16:37:34.868 Host name: WanIP (Port: 999)
. 2017-08-02 16:37:34.868 User name: get (Password: Yes, Key file: No)
. 2017-08-02 16:37:34.868 Tunnel: No
. 2017-08-02 16:37:34.868 Transfer Protocol: FTP
. 2017-08-02 16:37:34.868 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2017-08-02 16:37:34.868 Proxy: none
. 2017-08-02 16:37:34.868 FTP: FTPS: Implicit SSL/TLS; Passive: Yes [Force IP: No]
. 2017-08-02 16:37:34.869 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2017-08-02 16:37:34.869 Cache directory changes: Yes, Permanent: Yes
. 2017-08-02 16:37:34.869 DST mode: 1
. 2017-08-02 16:37:34.869 --------------------------------------------------------------------------
. 2017-08-02 16:37:35.046 Connecting to WanIP:999 ...
. 2017-08-02 16:37:35.073 Connected with WanIP:999, negotiating SSL connection...
. 2017-08-02 16:37:35.145 SSL connection established. Waiting for welcome message...
< 2017-08-02 16:37:35.145 220-FileZilla Server version 0.9.34 beta
< 2017-08-02 16:37:35.145 220 Willkommen am FTP Server
> 2017-08-02 16:37:35.145 USER get
< 2017-08-02 16:37:35.173 331 Password required for get
> 2017-08-02 16:37:35.173 PASS ********
< 2017-08-02 16:37:35.204 230 Logged on
> 2017-08-02 16:37:35.204 SYST
< 2017-08-02 16:37:35.235 215 UNIX emulated by FileZilla
> 2017-08-02 16:37:35.235 FEAT
< 2017-08-02 16:37:35.267 211-Features:
< 2017-08-02 16:37:35.267 MDTM
< 2017-08-02 16:37:35.267 REST STREAM
< 2017-08-02 16:37:35.268 SIZE
< 2017-08-02 16:37:35.268 MODE Z
< 2017-08-02 16:37:35.268 MLST type*;size*;modify*;
< 2017-08-02 16:37:35.268 MLSD
< 2017-08-02 16:37:35.268 AUTH SSL
< 2017-08-02 16:37:35.268 AUTH TLS
< 2017-08-02 16:37:35.268 UTF8
< 2017-08-02 16:37:35.268 CLNT
< 2017-08-02 16:37:35.268 MFMT
< 2017-08-02 16:37:35.268 211 End
> 2017-08-02 16:37:35.268 PBSZ 0
< 2017-08-02 16:37:35.298 200 PBSZ=0
> 2017-08-02 16:37:35.298 PROT P
< 2017-08-02 16:37:35.326 200 Protection level set to P
. 2017-08-02 16:37:35.326 Connected
. 2017-08-02 16:37:35.326 --------------------------------------------------------------------------
. 2017-08-02 16:37:35.326 Using FTP protocol.
. 2017-08-02 16:37:35.327 Doing startup conversation with host.
> 2017-08-02 16:37:35.327 PWD
< 2017-08-02 16:37:35.354 257 "/" is current directory.
. 2017-08-02 16:37:35.354 Getting current directory name.
. 2017-08-02 16:37:35.354 Startup conversation with host finished.
. 2017-08-02 16:37:35.354 Listing file "/Prod/Autoit/SG/Sg.exe".
. 2017-08-02 16:37:35.354 Retrieving directory listing...
> 2017-08-02 16:37:35.354 CWD /Prod/Autoit/SG/
< 2017-08-02 16:37:35.384 250 CWD successful. "/Prod/Autoit/SG" is current directory.
> 2017-08-02 16:37:35.384 PWD
< 2017-08-02 16:37:35.417 257 "/Prod/Autoit/SG" is current directory.
> 2017-08-02 16:37:35.417 TYPE A
< 2017-08-02 16:37:35.448 200 Type set to A
> 2017-08-02 16:37:35.448 PASV
< 2017-08-02 16:37:35.477 227 Entering Passive Mode (WanIP,198,232)
> 2017-08-02 16:37:35.477 LIST -a
< 2017-08-02 16:37:35.523 150 Connection accepted
. 2017-08-02 16:37:35.568 SSL connection established
< 2017-08-02 16:37:35.570 226 Transfer OK
. 2017-08-02 16:37:35.570 Directory listing successful
. 2017-08-02 16:37:35.572 Disconnected from server
memnon
$get1="""get /Prod/Autoit/SG/Sg_version.txt d:\tmp\"""
$cmd5 = 'c:\tmp\winscp425.exe /command "option batch on" "option confirm off" "open ftp://get:pw@WanIP:Port -hostkey=""ssh-dss 1024 numbers"" -implicit -passive""" ' &$get1& ' "exit"'
run($cmd5,"c:\tmp")
works - i get the Sg_version.txt
$get2="""get /Prod/Autoit/SG//Sg.exe d:\tmp\"""
$cmd8 = 'c:\tmp\winscp425.exe /command "option batch on" "option confirm off" "open ftp://get:WanIP:Port -hostkey=""ssh-dss 1024 numbers"" -implicit -passive""" ' &$get2& ' "exit"'
run($cmd8,"c:\tmp")
doesnt work and generates the log i postet, the sg.exe is 8mb - is that a kind of a bug ? do i code something wrong ?
memnon
well i found it out myself - the winscp425 was the problem, with the never versions it works...
problem is i wanted to use 425 because its only 1.6mb vs 14mb with the newest version
4.2.5 portable executable is compressed with upx, that's why it's so much smaller.
