delete files from source directory after download
noade-haan
hi
is there a way to delete files from the original directory after download?
I need to make sure those files will not be downloaded again to my local directory.
thanks,
Re: delete files from source directory after download
Use "Files > Download and Delete" command.
Or are you using scripting or any other kind of automation?
I used -delete to the get command, but why deleted file move to my local directory not to rubbish bin. Help me please, my command like:
get -delete /data/backup/*20210302
*batch script.
Do you want to only delete the files, without downloading them? Then don't use get, but rm:
rm /data/backup/*20210302
