WinSCP freezes upon upload
TheFreeWindows
This is a strange problem. WinSCP updates a file on the server using the command to keep a directory updated automatically, but it freezes when I select manually the "Upload" command. I have to terminate it, because it never comes back to life! I use v. 5.9.6 (I had the problem with the previous version too) on Windows 10, 64bit.
Re: WinSCP freezes upon upload
Re: Debug
My response to your email was rejected due to:
The message you sent to ... was rejected because it would exceed the quota for the mailbox.
