Connect on 2nd Server over the first one ?
aNj
Hi!
Is there a posibility to connect to a server which is not avaiable directly through ssh.
Normaly i use putty to connect to first one, and then I connect with the ssh command to the second server, but I want the features of SFTP?!?!
How does it work?!
Thx!
Best regards!
aNj
Re: Connect on 2nd Server over the first one ?
With SFTP you cannot do this. With SCP, it is theoretically possible. Try to search the forum, you may find hints from other users.
