Automate file synchronization from Folder to SFTP server
matrixebiz
Hello, can anyone please provide me the instructions on how to synchronize a folder on my Windows 7 computer whose contents are constantly changing (so will need to loop the script) with my SFTP server.
Thank you
Re: Automate file synchronization from Folder to SFTP server
Few options:
1) Use keepuptodate command instead of synchronize
https://winscp.net/eng/docs/scriptcommand_keepuptodate
2) Loop the WinSCP script in a batch file:
:retry
winscp.com /script=...
timeout /t 10
goto retry
For a similar task (just an opposite direction), see:
https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date#scripting
3) To avoid reconnect for each retry, use PowerShell script with WinSCP .NET assembly instead of simple scripting:
https://winscp.net/eng/docs/library_powershell
Again, for a similar task, see:
