Occasional hang
hadrien
Occasional hang
I have a scheduled task (every 2 minutes) which calls via a Perl script WinSCP to upload files using scripting, not the GUI.
Sometime WINSCP get stuck and doesn't exit (approximately one session every day). It is random and not related to a time of the day or another factor. I am also unable to reproduce it.
I am using WinSCP Version 5.5.5.4605 - Windows Server 2012.
The Perl part is like this one:
my $pobj;
my $cmdline="\"$winscppath\" /console /script=$script /log=$log";
Win32::Process::Create($pobj,
                        $winscppath,
                        $cmdline,
                        ,0,
                        DETACHED_PROCESS,
                        ".") || die "Create: $!";
do {
   $pobj>Wait(500)
   $pobj>GetExitCode($exitcode);
        if ($exitcode eq STILL_ACTIVE) {
}while ($exitcode eq STILL_ACTIVE && timeout);
The winscp script ($script file above) looks like:
option batch abort
open SFTP://XXXX:YYY@server -hostkey="ssh-rsa XXXXXXX" -rawsettings compression=1
option transfer binary
cd FOLDER
Put file1.ftp file1.ftp
Put file2.ftp file2.ftp
See Winscp.ini and log in attachment.
I hope that it can point to root cause, even though reproducing the issue is not clear. Is there something wrong in my configuration? Is there a work around? Many thanks.
  • winscp.log (8.12 KB, Private file)
Description: logs
  • winscp_ini.txt (10.97 KB, Private file)
Description: winscp.ini
hadrien
Re: Occasional hang
I update to the lastest version 5.9.6. Unfortunately, I still get the same issue.
The Perl part and the config haven't been changes.
Please see an example of winscp new log in attachment.
Many thanks for looking at this.
  • winscp.log (8.34 KB, Private file)
Description: Winscp log v 5.9.6
Re: Occasional hang
Thomas_C
Hanging logs
Hi I'm Thomas, working with hadrien. We have been able to reproduce the issue with your debug version, you'll find log and trace there :
ftp://winscp_tests:winscp1234@www.mybreuil.com
Just to remind you the issue, we launched winscp through the win32::Process at 8:05, then last log in standard log happened at 08:07:01, and 08:11 in trace, but process remains STILL_ACTIVE until 08:35 when we manually killed after TIMEOUT.
The global context is a Scheduled Task.
Many thanks,
Thomas.
hadrien
Hi Martin,
we finally reproduce the issue with the new build. Seems to be related to a MessageDlg that popup even in command line... In attachment the logs. Thanks for your investigation.
  • winscp-20170830211006.log (202.46 KB, Private file)
hadrien wrote:
Hi Martin,
It seems that some runs of the task overlap and they fight over an INI file.
Few possible solutions:
- Do not rely on an external configuration at all: https://winscp.net/eng/docs/scripting#configuration
- Set INI file read only: https://winscp.net/eng/docs/config#ini_readonly
- Use registry instead of an INI file
Pyre909
Utah
Application Hang on Windows 10 Version 1803
Hi Martin,
Lately I have experience random hangs in Winscp. I never had any on prior to 1803.Currently trying to recreate the issue and see if I can get it captured on the log.
Regards
Re: Application Hang on Windows 10 Version 1803
What version of WinSCP are you using? Do you have any idea/suspicion what operation/event causes the hang?
Pyre909
Utah
Hi Martin,
Most of the time it deals with moving files from the remote server to local. There is a slight pause when dragging and dropping then it allows the operation.
Version: 5.13.3
Windows 10 version 1803 x64
Re: Was this issue fixed?
nkarkacheva wrote:
If yes - in which version?
Which issue? This topic includes multiple unrelated problems already. The best would be, if you start a new thread and describe the specific problem you are facing.
