Error uploading particular PDF
faguirre
Uploading a batch of PDF files one of them get us an error:
ERROR:
"Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD
Failure reading network stream."
We've tried this:
1 - Zip the file => This works
2 - Change the name of the file: => Doesn't work
3 - Edit connection -> Advanced -> Connection -> TLS/SSL -> Maximun TLS/SSL Version set on 1.0 => This works
  • 2017-06-07_15-01-37.png (149.21 KB, Private file)
Re: Error uploading particular PDF
Can you download the .pdf using any other FTPS client, like FileZilla?
faguirre
Yes, I can upload and download all files with all clientes (Filezilla, CyberDuck).
Where is the session log?
There are instructions in my previous post.
faguirre
Sorry, I didn't see that.
I'm not using winscp server, I'm using vsftpd. I attach the log from there. Also I'm attaching a pic of the error.
  • 2017-06-09_10-40-29.png (191.12 KB, Private file)
Sorry, but I was asking for WinSCP log file.
FileZilla or CyberDuck (verbose) log file would help too, for comparison.
Can we see a corresponding verbose log files of the other FTP clients?
Is it always this one particular file? Is the problem consistent? Can we get a copy of the file?
I cannot reproduce the problem using the same encryption algorithms.
The FileZilla log does not contain any information about encryption algorithms. Would it, if you set higher logging level?
Any reason you are using implicit TLS/SSL encryption? Did you try explicit?
