Connect to multiple servers in one powershell script
GRR3
I'm learning powershell and also am new to OOP.
If I wanted to download from one SFTP server and upload to a second server in the same script, would this be the general idea (below)?
Is there a better way to do this?
Thank you.
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "example.com"
        UserName = "user"
        Password = "mypassword"
        SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
     $sessionOptions_second_server = New-Object WinSCP.SessionOptions -Property @{
        HostName = "example2.com"
        UserName = "user2"
    $session_second_server = New-Object WinSCP.Session
    try
      # Connect to download from server 1
        # Download files
        $transferResult = $session.GetFiles("/home/user/*", "d:\download\", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
      $files_downloaded = 0
            Write-Host ("Download of {0} succeeded" -f $transfer.FileName)
         $files_downloaded++
      if ($files_downloaded)
         # Connect to upload to server 2
         $session_second_server.Open($sessionOptions_second_server)
         # Upload files
         $transferOptions_second_server = New-Object WinSCP.TransferOptions
         $transferOptions_second_server.TransferMode = [WinSCP.TransferMode]::Binary
         $transferResult_second_server = $session_second_server.PutFiles("d:\download\*", "/home/user/", $False, $transferOptions_second_server)
         $transferResult_second_server.Check()
         # Print results
            Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
    finally
        # Disconnect, clean up
        $session.Dispose()
      $session_second_server.Dispose()
    exit 0
catch [Exception]
    Write-Host ("Error: {0}" -f $_.Exception.Message)
    exit 1
Re: Connect to multiple servers in one powershell script
Looks good.
Just that you should close the first session - $session.Dispose(), as soon as you do not need it - just after the download.
