Cannot login to site with Passphrase
Hi I'm using WinSCP 5.9.5.0
I've made a script to download some files from a remote site which uses a private key and a passphrase.
The Winscp part of the script is
# Load WinSCP .NET assembly
Add-Type -Path "E:\location\WinSCPnet.dll"
# Setup session options
HostName = "data.xxxxxxxxxx.com"
UserName = "my username"
PrivateKeyPassphrase = "*P,7$+Y#}^k@^"
SshPrivateKeyPath = "E:\location\bdl.ppk"
SshHostKeyFingerprint = "ssh-rsa 1024 the fingerprint"
And when I run the script I'm getting
Member "PrivateKeyPassphrase" not found for the given .NET object.
What am I doing wrong?
Re: Cannot login to site with Passphrase
Your code is correct. If it does not work, it's probably because you are actually not using WinSCP .NET assembly 5.9.5, but some older one.
support@heens-it.be wrote:
Hi Martin,
is it possible it gets the dll from another place? as in the scriopt i'm directing it to the 5.9.5 version ;-)
Sorry, I do not understand. What "another place"? How are you "directing it"?
support@heens-it.be
With directing, I meant "Add-Type -Path "E:\location\WinSCPnet.dll"
But I've found it...
It seemed that I had to close the powershell windows and reopen it, because it held the old dll in memeory instead of loading the correct one with the "Add-Type -Path "E:\location\WinSCPnet.dll" command
