Local and remote is 1 hour different.
BoD
I am sorry for my English.
My local PC is with WinXP SP3.
If remote server is with Win OS, all is OK.
But if remote server is with Unix OS - time transfer file is +1 hour.
Transfer protocol mus be FTP only.
How transfer from WinXP SP3 to Unix and FTP transfer protocol with correct time?
Thank You for help me.
Re: Local and remote is 1 hour different.
Please attach a full session log file showing the problem (using the latest version of WinSCP). Select a single file for the test. Tell us what timestamp do you see in a remote panel before a transfer, if that's correct or not and why. And what timestamp does a local file have after the transfer (or other way around, if you are uploading).
It does not look like 1 hour difference problem.
It actually looks like the server is not able to update file timestamp at all.
The timestamp of the remove file is a time of the upload.
. 2017-06-05 06:42:14.961 File: 'C:\FrontPage Webs\Content\kc-uo\index.htm' [2017-06-05T03:32:04.243Z] [6135]
> 2017-06-05 06:42:15.399 MDTM 20170605033204 index.htm
< 2017-06-05 06:42:15.430 550 Can't check for file existence
. 2017-06-05 06:42:17.680 type=file;size=6135;modify=20170605044215;UNIX.mode=0644;UNIX.uid=1104;UNIX.gid=1010;unique=fe11g6a6ad1; index.htm
