More Putty session support
Michael
It would be great if WinSCP could just use the Putty registry entries instead of importing them. Also, not all of the Putty session info comes across. :cry:
Re: More Putty session support
WinSCP has some additional options that Putty has not and vice versa. It could happen that future version of Putty would use option with same name (registry key) as WinSCP does. So the program would overwrite settings of each other.
Which options?
