(ESshFatal) Server unexpectedly closed network connection
rohit
hi all
using WinSCP & Putty
Earlier was getting connected to both, Putty & WinSCP
but not for last 2 days, without any changes
error log::
. 2005-10-11 18:21:20.125 --------------------------------------------------------------------------
. 2005-10-11 18:21:20.125 Looking up host "jervis.textdrive.com"
. 2005-10-11 18:21:20.500 Connecting to 207.7.108.211 port 22
. 2005-10-11 18:21:26.093 Server unexpectedly closed network connection
* 2005-10-11 18:21:26.093 (ESshFatal) Server unexpectedly closed network connection
plz help!!
Re: (ESshFatal) Server unexpectedly closed network connection
Can you connect with PuTTY? Do you see incoming connection is log of the SSH server?
rohit
i m extremely sorry prikryl, i was not in proper way.
Session name: circleadmin@jervis.textdrive.com
Host name: jervis.textdrive.com (Port: 22)
User name: circleadmin (Password: Yes, Key file: No)
Transfer Protocol: SFTP (SCP)
SSH protocol version: 2; Compression: No
Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
SSH Bugs: -,-,-,-,-,-,-,-
SFTP Bugs: -,-,-
Proxy: none
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default, EOL: 0
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
i m also not able to connect putty, giving sane error. (as putty fatal error). I tried to get the log for putty also, but couldnt.
i m putting its loggin on, & its swith it to off, so blank file "Putty.log".
sorry again , plz guide
[/img][/url]
DB
Any resolution
Hi there, I'm seeing exactly the same issue as the OP.
I was able to connect via WinSCP to our SFTP server a few times and then suddenly the same error appeared.
It seems as though the server instantly disconnects my connection attempt. I am also unable to telnet to the server, whereas I was able to do so when i could stil WinSCP to the server.
I would like to know if there was a resolution to the OP's issue or what I can check for on our server which might be preventing me from connecting.
Re: Any resolution
It looks like a server-side problem. You should contact your server administrator.
