Script problems
GrahamBall
Script problems
I have a script in which I've tried to use cd\ and cd.., but have been informed that they are not recognised.
I get 'Error changing directory to '\'.'
The way round is to disconnect and reconnect, but why aren't these commands supported.
I was under the impression that the call command was supported, so I also have - call wait.bat 10 to give the time for the server to process my input file, before I go looking for the results, to which I get
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Connection has been unexpectedly closed. Server sent command exit status 254.
Isn't this a Windows app?
thx Graham
Re: Script problems
What about "cd /"? SCP/SFTP uses unix-style paths.
Command "call" runs the command on remote server!
Well I wouldn't have guessed that a self-styled 'Windows' program would use Unix conventions.
I couldn't find any help on the supported 'Dos' commands, so I guess you only get that help from a Unix system.
Thanks,
GRaham
How do you want to transform unix style paths to windows style?
You cannot expect any help. WinSCP simply passes the command to the server. It does not interpret, nor understand it in any way. So it supports commands that the remote side supports, which differs.
