[.NET Assembly] Invalid number of arguments MLST
glacierlee
I am who I am
I am currently using the .NET library to download files from my application. However, I encountered the following issue during the FTP download.
I tried to download the file through FileZilla Client with no problem.
Library Version: 5.9.4
Protocol: FTP
Can't get attributes of file '/teck/csv/serials_incremental_27_04_2017 11_43_31.csv'.
Could not retrieve file information
Anybody can tell me how to fix this error? Thank you.
  • ftp.log (7.61 KB, Private file)
Description: Full Session Log
Re: [.Net Assembly] Invalid number of arguments MLST
You seem to have tried to quote the path somehow. Did you? What is your code like?
Use just a simple path, no quoting. If that does not work, post a log file for that.
glacierlee
I am who I am
Yes, actually I didn't quote the path initially, but it didn't work. Then I tried to quote the path still no help.
Here is my code after removing the quote, and attached is the log.
// Setup session options
    HostName = "xxx.xx.xxx.xx",
    UserName = "FTPUser",
    Password = "Password",
    PortNumber = 21,
    Protocol = Protocol.Ftp
    try
        // Connect
        session.SessionLogPath = "e:\\temp\\ftp.log";
        session.Open(sessionOptions);
        var remoteFileInfos = session.EnumerateRemoteFiles("/Inbox/csv", "*.csv", EnumerationOptions.None)
            .Where(file => !file.IsDirectory)
                .OrderByDescending(file => file.LastWriteTime);
        foreach (var remoteFileInfo in remoteFileInfos)
            var remoteFile = session.EscapeFileMask(String.Format("{0}", remoteFileInfo.FullName));
            var localFile = Path.GetFullPath(String.Format("e:\\temp\\{0}", remoteFileInfo.Name));
            if (!remoteFileInfo.Name.IsNullOrEmpty())
                session.GetFiles(remoteFile, localFile,false).Check();
                var archiveFilePath = session.EscapeFileMask("/Inbox/Backup" + "/" + remoteFileInfo.Name);
                if (session.FileExists(archiveFilePath))
                    session.RemoveFiles(archiveFilePath);
                session.MoveFile(remoteFile, archiveFilePath);
        session.Close();
    catch (Exception ex)
        session.Dispose();//Release session
        txtOutput.Text = $"{ex.Message}\r\n{ex.StackTrace}";
    // Download the selected file
  • ftp.log (7.53 KB, Private file)
Your code is correct. I have successfully tested it against couple of servers.
It looks like a server-side problem/incompatibility. FTP commands should require no quoting.
Are you using the latest version of the server?
glacierlee
I am not sure, the server is holding by one of our customers.
However, I have tried the .NET FtpWebRequest with no problem.
glacierlee
I am who I am
Sure, below are the codes I tested with FtpWebRequest:
Uri ftpUri = new Uri("ftp://FTPuser@xxx.xx.xxx.xx/Inbox/csv/serials_incremental_27_04_2017 11_43_31.csv");
FtpWebRequest ftpRequest = (FtpWebRequest)WebRequest.Create(ftpUri);
FtpWebResponse ftpResponse = null;
FileStream ftpfile = new FileStream("e:\\temp\\FTP\\serials_incremental_27_04_2017 11_43_31.csv", FileMode.Create);
ftpRequest.Credentials = new NetworkCredential("FTPuser", "Password");
ftpRequest.Method = WebRequestMethods.Ftp.DownloadFile;
ftpRequest.UseBinary = true;
ftpResponse = (FtpWebResponse)ftpRequest.GetResponse();
Stream ftpstream = ftpResponse.GetResponseStream();
byte[] ftpbyte = new byte[2048];
int readcout = 0;
readcout = ftpstream.Read(ftpbyte, 0, 2048);
while (readcout > 0)
    ftpfile.Write(ftpbyte, 0, readcout);
ftpfile.Close();
ftpResponse.Close();
ftpstream.Close();
  • ftp.log (2.71 KB, Private file)
As you can see in the log, the FtpWebRequest does not quote the path in the RETR command either.
System.Net Information: 0 : [7956] FtpControlStream#61476884 - Sending command [RETR Inbox/csv/serials_incremental_27_04_2017 11_43_31.csv]
What if you set the Method to GetDateTimestamp or GetFileSize?
glacierlee
I am who I am
I tried both methods with no problem. But I get the following error when I tried ListDirectory.
The remote server returned an error: (501) Syntax error in parameters or arguments.
   at System.Net.FtpWebRequest.SyncRequestCallback(Object obj)
   at System.Net.CommandStream.Dispose(Boolean disposing)
   at System.IO.Stream.Close()
   at System.Net.ConnectionPool.Destroy(PooledStream pooledStream)
   at System.Net.ConnectionPool.PutConnection(PooledStream pooledStream, Object owningObject, Int32 creationTimeout, Boolean canReuse)
   at System.Net.FtpWebRequest.FinishRequestStage(RequestStage stage)
   at System.Net.FtpWebRequest.GetResponse()
   at EdiTranslatorTest.frmMain.DownloadFtpByWebRequest() in E:\Work\Development\DOTNET\EDI Hub\Code_NH\EdiTranslatorTest\frmMain.cs:line 187
   at EdiTranslatorTest.frmMain.btnTest_Click(Object sender, EventArgs e) in E:\Work\Development\DOTNET\EDI Hub\Code_NH\EdiTranslatorTest\frmMain.cs:line 40
So it's indeed a bug in the server. It behaves inconsistently with different commands.
