WinSCP Freeze when I sync an image from local to server
kormoskrisztian
Hungary
Dear Support!
When I'm in Active mode and I want to upload an image or some of php file the WinSCP just freeze out without any error message. :/
I used the latest 5.9.5 version on Window 10!
It started about 2 weeks ago, but I didn't install any program or change any options. : /
Any idea what can I do in theese case?
I attached a file if it helps.
Thank you for your help,
Best regards,
Chris
  • winscp_bug_2017_04_26.png (83.47 KB, Private file)
Description: Freeze
Re: WinSCP Freeze when I sync an image from local to server
Thank you for your great assistance Martin!
The solution for me it was the following steps:
Step 1 - I delete all folders / files from my local
Step 2 - Do new copy from server to local map
So be sure all folders and files are the same!
Best Regards,
Chris
