ftps issue
joe_bai
cn
ftps issue
I tried passive mode and set the firewall setting support, give the scope 5000-6000,but still does not work.
Windows server 2012 + ssl + ftp
I have outside IP.
Tried to use no ssl, i can login in the ftp.
joe_bai
ftps issue
Yes, i did all the steps. If i use it without ssl i can login in. On the server i used winscp and use domain name or IP to login, i can login.
Re: ftps issue
That indicates that you did not setup the firewall according to the guide.
Did you really enable all tree firewall rules? Did you restart the FTP server (or even the whole server)?
joe_bai
cn
Re: ftps issue
I fixed it. Because our cisco asa firewall has other rule to block it. Thank you so much.
