Session looks like it starts, but then it closes?
youradds
UK
I've got a really annoying issue, and I don't know what to do about it. When I start the session, it loads as the below image – but then closes!
It used to work fine, so I'm not sure what has changed. I recorded the screen and then freeze-framed it to find what the message was (as it closes too quickly, that you can't read it)
Any ideas as to what could be causing it? I've had this a couple of times before, but I then moved host and haven't had a problem since. However, its arisen its head again :(
Cheers Andy
Re: Session looks like it starts, but then it closes?
Though note that it's clearly server-side problem. I just want to find out, why WinSCP does not report any meaningful error message.
youradds
UK
Thanks. That got me on to the right track :)
Thanks. For some reason I get a different error message in that version.
Server sent command exit status 127
Cannot initialize SFTP protocol. Is the host running an SFTP server?
Doing a google, I came across:
Can connect via SSH - but not via SFTP? Exit status 127
In particular:
For me it was client configuration fault. 127 code means that command wasnt found. I changed WinSCP config to use "/bin/sftp-server" instead of "default" by mistake. Check your client config.
Sure enough, if I change the setting in Advanced > SFTP > SFTP Server to /bin/sftp-server, then it works! Not ideal, but at least I have a work-around.
Looking at the versions, I have 5.9.5
Hopefully this will help someone else in the future :)
Cheers Andy
I wrote this via email already, just for the others:
That indicates that the SSH server is misconfigured. When asked to run "sftp" server it fails (probably because its mapping for "sftp" subsystem points to an invalid path). You have worked around the misconfiguration. You should get the server fixed instead.
youradds
Yeah, I'm still trying to work out why the server is being weird :( As I mentioned earlier, it DID used to work fine – but after about a week, it started with this issue. So I'm not sure if it's something that I've installed that has messed it up, or something else.
