MV COMMAND
LICE
MV COMMAND
I have a script with mv to rename a *.file to 1 and it runs fine when I am in the winscp> prompt but when I call a script it fails to rename the file.
cd /remotefolder/
put -filemask=>8K;|>1D; *.bin /remotefolder/
rm 1
mv *.bin 1
Do I need to call the full path?
mv /remotefolder/*.bin /remotefolder/1
Re: MV COMMAND
LICE
MV COMMAND
I am just removing the old 1 and rename %random%.file to 1. Should I try "rename" alias? Could it be the * in the mv command might expect more that one file and I am just rename one file?
script
rm 1
mv *.file 1
ls
mv *.file 1
mv *.file 1
mv *.file 1
mv *.file 1
mv *.file 1
log
. 2017-04-21 01:31:40.278 Directory listing successful
. 2017-04-21 01:31:40.278 Got reply 1 to the command 2
< 2017-04-21 01:31:40.278 Script: Can't get attributes of file '1'.
< 2017-04-21 01:31:40.278 File or folder '1' does not exist.
. 2017-04-21 01:31:40.278 Script: Failed
. 2017-04-21 01:31:40.278 Session upkeep
. 2017-04-21 01:31:40.278 Script: Exit code: 1
. 2017-04-21 01:31:40.278 Script: Max roundtrip: 0
. 2017-04-21 01:31:40.278 Got reply 1004 to the command 2
. 2017-04-21 01:31:40.278 Disconnected from server
