DirectoryExists?
Re: DirectoryExists?
vtthinh wrote:
In FileTransferProgressEventArgs, i see CPS but I want to get transfered bytes. Do you show me?
That's not available.
You can only sum sizes of completely transferred files in Session.FileTransferred event.
vtthinh
Can you do it?
And I have a new question
I need get "Session Time" follow by ETSI TR 102 678 V1.2.1 (2011-05):
5.1.1.3 Trigger Points
The average throughput is measured over the time interval Δtd starting from the successful establishment of the data connection.
Download:
Start: File download starts. Start Method A: Reception of the first data packet containing content.
Start Method B: Reception of the [ACK] from the [SYN, ACK] for active mode connections, sending of the [ACK] for the [SYN, ACK] for passive mode connections on the data socket.
End: End of measurement time interval reached.
Stop: time Δtd elapsed since start trigger event.
Upload:
Start: File upload starts. Start Method A: Sending of the first data packet containing content.
How can I get Trigger Points of Start and End of the transfer?
Thanks in advance!
vtthinh wrote:
Can you do it?
Do what?
That again is the time the Session.FileTransferred is called.
vtthinh
Do what?
Ah, current In FileTransferProgressEventArgs can not get bytes transferred
]That again is the time the Session.FileTransferred is called.
Thank you!
vtthinh wrote:
Do what?
OK, I'll consider this.
