Error in Authenticating Host Key
scates
We are upgrading servers and have an SFTP protocol script connecting to a site using 5.1.4 which is currently working fine.
However, when we use the same script using 5.9.3 version it gives the following error:
Host key fingerprint is SSH-RSA 1024 55:61.....
Authentication failed
this is the command line we are using to test the connection:
>winscp.com
winscp>option batch abort
winscp>option confirm off
winscp>open sftp://martin:ppppppp@host.com -hostkey="ssh-rsa xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
I cannot find any documentation regarding the 1024 or 2048 options on the ssh-rsa in the host key. Is that the cause of the error?
The new server is a windows server 2012 R2.
scates
Possible issue
The host key we are using was supplied by the customer. It is way over 16 characters and does not have any colons.
Re: Possible issue
Does it start "ssh-rsa 5561", i.e. does it match the key shown by WinSCP (despite a different syntax)?
If it does, just use the format that WinSCP shows.
