Winscp will fail to move a file inside a rclone mount
eumesmo
Apr 6 05:57:06 ubuntu sftp-server[2293]: rename old "/home/qbtuser/1234d" new "/home/qbtuser/upload/1234d"
Apr 6 05:57:06 ubuntu sftp-server[2293]: sent status Failure
If I try to move a file using the GUI to a rclone mount I'll always fail.
Winscp can create/delete/rename files inside the mount just OK. but moving to the mount it fails.
Why ? I'm root on my session
Re: Winscp will fail to move a file inside a rclone mount
What makes you think this is a problem of WinSCP? This is server log.
Can you move the file using any other SFTP client?
